Question about Intertherm P3RA-048K Air Conditioner
No cold air blowing out just warm air
The ac gradually started getting warmer over the period of about two hours. Nothing appears to be frozen up, all fans are working inside and out. It sounds like something is trying to kick on and wont. What can i check
    Novelist:
  • 145 Answers
Tray washing the condenser side (out side ) whit a water hose and changing your home air filter
especially your condenser "(the part than looks like a radiator)"
if is real dirty it can't bread and cool down
the refrigerant causing a the refrigerant pressure to rice to unsafe levels and a safety pressure switch kill the compressor.
all other fans will work.
do not use a hi power pressure washer because it would bend the tiny aluminum strips and cause you more troubles.
if this don't work you are going to have to call a pro to take care of it.
Posted on Jul 03, 2009
I need to turn off my gas f/freezer. The water part doesn't work. I was told to turn off for 48 hrs.then will be ok. Is this true. Apparently the inside door has frozen.
Turning off the unit will thaw a frozen water line in 24 hours or less Turn it back on and if you get water flow, then turn your cold control to a warmer setting, if it still freezes up, replace the cold control.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 15, 2017 | Refrigerators
My whirlpool fridge is getting warmer
there is a dampener control that lets air over to ref section, put your hand at the area to see if air is coming over from freezer.
if not look in freezer in back to see if it is all frozen, if so call tech.
if not push light button in freezer side with door open and liston for fan if fan does not run that is your problem.
May 03, 2014 | Whirlpool Refrigerators
The freon is fully charged but the air keeps getting warmer until there is no longer any cold air. It still blows air but it's warm. Does this sound like the compressor is bad??
do you have to recharge it after it starts blown warm if so its just got a leak and leaking all your freon out if its holding all freon then compressor must be bad
Sep 14, 2012 | Air Conditioning and Heat for Isuzu Axiom
AC blows warm air whil idle or at first start
U could be run on eco a/c where the engine is using the power until it has extra to spare. Warm at start could be simlarly that there is now cold air yet and has to "make" cold air to distribute when ready. See if u can find a setting for reg use. cheers, ps eco saves dollars/euros.
Sep 05, 2012 | 2005 Audi A4
My house air conditioner will blow cold air for a while when it is really hot outside ( i live in the california desert area ) but nothing but warm air will come out after the ac has been working for a...
Hi and welcome to FixYa, I am Kelly,
This certainly sounds like a low system coolant level issue. Have someone check the system pressures. Low side should usually be 65 to 70 unit running. High side will vary with outside temps any where from 135 - 170. If you do not have good low side pressures it will affect the high side pressures also. This is really the only way your going to sort this one out.
Look around the evaporator and the condenser for any signs of OIL or dark spots caused by oil. That is usually an indication of a system coolant leak.
Thanks for choosing FixYa,
Kelly
This is who answered your question:
http://blog.fixya.com/index.php/2010/05/award-winning-service
Jul 10, 2011 | Heating & Cooling
My westinghouse fr/frz has been gradually getting warmer. The meat has defrosted in the freezer and there is no cold air in the fridge. I can hear a noise behind the appliance. Could it be the fan?
try to check your evaporator fan inside the cabinet if working together the condenser fan if working maybe compressor trip off conduct cleaning of yuor condenser if dusty adjust thermostat setting to coolest. maybe your fan hits some parts check it or apply lubricants on bearings.
Feb 27, 2011 | Refrigerators
I have an old Kenmore 25,000 BTU Air Conditioner (Model number 253.7792580). Recently it started blowing air that is not really cool, it's actually room temp. It makes a slightly different sound when it is...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 29, 2010 | Kenmore Heating & Cooling
Intertherm P3RA-048K Air Conditioner Logo
203 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
