Question about GE PSC23NHN Side by Side Refrigerator
Freezer stays cold and refrigerator side is warm
    Sergeant:
    Champion:
  • 235 Answers
First check that nothing is blocking air circulation to the fridge from the freezer. Is the fan running ? You can usually hear it when you open the freezer. If not running , it needs replacing.
Posted on Jul 03, 2009
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
The freezer side quit staying cold today. No
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 28, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
sfjfg
Aug 16, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Freezer works fridg dosent stay cold
When plugging it back in, check to see if you can feel air circulation (from vents in the top-rear) on the refrigeration side.
Check again after the fridge starts to warm.
There is a fan which is supposed to distribute the cooled air from the freezer to the fridge; this may be failing after the fan has warmed from operation. The bearings in these is primitive and can get sticky impeding the fan's rotation. Replacement of that fan is not covered by the (longer) compressor warranty.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator stays warm freezer stays cold
You need to check the back of the freezer for frost build up... most of the time when that happens you have a defrost problem or you fan is not working or its blocked, check that by taking off the back panel in your freezer....
Jun 24, 2009 | GALAXY Microsystems 25.4 cu. ft....
Freezer side cold, food side warm not working
3 possible problems.... Machine is possibly not defrosting (if this is it, eventually the freezer will not work as well) The damper between the two sides is possibly not operating, or the fan on the freezer side is possibly not blowing the cold air into the fresh food side.
Mar 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge not cooling down stays at 68 degrees
you may be low on freon..thats one thing about fridges if you are low one side will still stay cold while the other side gets warm
Jan 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
WARM REFRIGERATOR
Check the freezer side back wall, do you see Ice forming on that wall?
If so you have a defrost issue. Also check to make sure you fan in the freezer side is running. If not, than cold air from the freezer cannot make it to the fresh food side.
I am factory authorized for Frigidaire Appliances and am confident I can assist you in this repair.
Bill
May 12, 2008 | Frigidaire FRS3R5EMB Side by Side...
GE PSC23NHN Side by Side Refrigerator Logo
166 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
