Question about EliteGroup 661FX-M Motherboard
Audio not working. No visible problems
Audio not working. All hardware reports no errors with all drivers installed. All PCIs are working also. Still problem. No visible problems
  • 37 Answers
If your sound card is not embedded into the motherboard and it's stand alone try switching it to another pci port on the mother board. If it's not stand alone check out the Asus forums
If it helps please rate/vote me
Posted on Jul 03, 2009
How Do I Fix Error Code 43 in Windows 7?
This is probably one of the most frustrating and "generic" error codes reported by Windows. When I say "generic", I'm referring to the fact that Windows is basically telling you that a hardware device on your PC is well... not working. (Gee, Thanks!)
Error code 43 is reported anytime Windows does not recognize a device - whether it be a USB port, Hard drive, video card or any other piece of hardware connected to your computer.
You will usually see an error message like this:
"Error Code 43: Windows has stopped this device because it has reported problems"
And if you look at the hardware under Windows device manager, you will see something like this:
NOTE: The hardware device above is only an example. It could be any device on your computer that is reporting error 43.
What Causes Error 43? 95% of the time, error code 43 means that a device driver is either missing, corrupt, outdated (so Windows problems communicating properly with the hardware), or the hardware is faulty and needs to be replaced.
Device drivers can become damaged or corrupt over time, and most users will eventually experience a driver error. Installing and removing software and hardware can cause conflicts in the registry and can alter driver communication.
Sometimes you can bypass the error temporarily such as removing the device from the motherboard and reseating it, removing the power cord from the power supply and restarting your computer after a few minutes, etc. However, theses are temporary and will not fix the actual problem.
Solution For Fixing Error Code 43 Messages The first thing of course is to make sure your device driver is up to date. I have provided two ways to accomplish this below:
Option #1: Update your drivers automatically (the easy way)
If your not that technical and don't want to hassle with trying to locate the correct device drivers from your PC's manufacturer and then go through the process of uninstalling and re-installing your drivers manually, then you should run a free scan with a recommended driver tool.
This software will match and download the correct drivers you need. It's safe and saves a lot of time keeping your PC updated.
Option #2: Update your drivers manually (the technical way)
If you consider yourself pretty technical and feel confident making changes to your system, then follow the steps below:
Step #1 - Uninstall the current driver:
First, you need to uninstall the current driver...
  • Click "Start > Run" and type "sysdm.cpl" in the text box and press ENTER
  • Open the "Hardware" tab on the System Properties dialog box, then click on "Device Manager"
  • Double click "Device Type", then click on the hardware device that is reporting Error 43
  • Next, go to the "Driver" tab and click "Uninstall" to uninstall the device driver completely
Step #2 - Locate the correct driver:
After you have uninstalled the driver, visit the manufacturers website and locate the newest driver for your device. You can usually find the latest driver under the technical support or driver section of the company's website.
Step #3 - Download the driver:
Download the driver and save it to your computer. It will most likely be compressed in a .ZIP file, or an executable file (.EXE).
Step #4 - Install the new driver on your PC:
Extract the .ZIP file or double-click the .EXE and install the driver.
Step #5 - Reboot your PC:
If you uninstalled the old driver and installed the correct new driver, it should fix the communication problem between Windows and your hardware device, eliminating the error 43 message. If not, you might want to install the faulty device on another PC and see if it works correctly.
If you continue to experience problems then most likely the device itself is damaged and needs to be replaced.
Good luck.
Semper Fi,
Z
Feb 19, 2018 | Computers & Internet
Audio sound device is not clear. //// intel motherboard dg31rp model system
hi..
There are various possible causes of the problems that occurred, including the problem of software drivers, operating system problems or problems of hardware (audio card)
do an audit to identify the problem occurred.
1 - remove the old driver and then reinstall the driver for audio card.
2 - you can make two choices if you want to reinstall the operating system or perform a test by installing new audio card.
(the installation of the operating system / format, is to ensure that the operating system is
100% working )
TQ
May 03, 2011 | Intel DG31PR Motherboard
What is code 1 and code 28 and how to repair?
All computer hardware needs device drivers to communicate with the operating system. In Windows quite a few device drivers are included with the installation. But for a lot of hardware, special device drivers are required. If drivers are corrupted or not installed properly, Windows will report a device error. One of the device errors that the Windows Device Manager can report is a code 28 error.
A code 28 error means that there is no driver installed for the hardware device. Most likely Windows does not have a default driver for the device, or it would be installed. This means that a special driver from the hardware manufacturer is required. The code 28 error can occur for any type of device, USB devices, audio devices, video devices, etc. In general however the error will occur for the more exotic hardware since Windows already supports quite a few common devices by default.
To fix code 28 errors, it is required to install the drivers for the device that is causing the code 28 error. You can use the device manager to update the drivers. Select the device in error, right-click the device and in the pop-up menu select Update Driver Software. Windows will ask you for the location to install the drivers from, so make sure you download the drivers for the device from the hardware manufacturer’s website first, and select the local folder where you saved the download drivers for the update.
If you can not find the drivers for the device in error, or are not comfortable in using the Windows Device Manager, you can also use a driver update tool to find, download and update all device drivers for you. A driver update program will accurately identify your hardware, including the device in error, and automatically install the latest drivers for it. This will solve code 28 errors.
It is also recommended to have Windows configured for automatic updates. This will ensure that any new drivers that are supported by Microsoft will automatically install or get updated, so that your computer will be compatible with as many devices and hardware as possible.
Code 1:
Error (Code 1) is a known error that is caused by outdated or corrupt drivers. Failure to keep your drivers up to date could result with system malfunctions and device problems.
Solution: It is highly recommended that you update your drivers now to fix the problem.
More Info: Device Manager may report about and provide resolutions. To view the error codes, follow these steps:
Click Start, click Run, and in the Open box, type control panel.
In Control Panel, double-click System, click the Hardware tab, and then click Device Manager.
Double-click a device type. For example, double-click Modems to see the devices in that category.
Double-click a device to view its properties. If an error code has been generated, the code appears in the Device Status box that is on the General tab.
Jun 22, 2010 | Intel Computers & Internet
I've wipro notebook,it's SI No.09HBRR00100038-CPU and model no.WNBMBM4900.I'm not getting install audio driver,when start to install display an error 503 report and failure.What can i do?Please give me a...
* Error 503 is for Display Driver failure!
1. Try to install a updated version of display driver!
2. Restart your system,and configure display settings.
* Please explain ur "Audio driver problem", what type of error message u got ?
Jan 02, 2010 | Computers & Internet
Failure in installation of audio driver after 51%
when you install the audio driver in your mothergboard don't press the new hardware found just leave it.. ok?
Aug 12, 2009 | Intel D945GCL Motherboard
Software error
hi, i think this link may solve your problem, in this page you can download the drivers detective software. http://laptops-notebooks-drivers.com/tag/vectron-m540bat-6-drivers
May 28, 2009 | Computers & Internet
Problem with audio driver
check your BIOS if the souncard is enabled.
install the chipset driver first
then install the sound driver.
be sure you are installing drivers for XP not Vista
Mar 23, 2009 | Compaq Presario 700 470024-192 Notebook
No sound from cd or dvd , they both work..but no sound
for windows xp platform, drivers are normally installed separately. Anyway try this trick
visit lavalys website and download everest corporate 460 trial version.
install it on your machine and run it select report and follow the wizard.
on the report files, select Hardware-related pages option
click next
on the report format, select html
click finish
allow it to run
when it done, it should give you a report
click Save to file to save it for your future needs(Remember where you saved it.)
back to you original report, Scroll down the report and you should see something like this:
[ South Bridge: [ TRIAL VERSION ] ] South Bridge Properties: South Bridge [ TRIAL VERSION ] Revision / Stepping 82 / B0 Package Type 421 Pin BGA Package Size 3.1 cm x 3.1 cm Core Voltage 1.5 V AC'97 Audio Controller: Audio Controller Type Intel ICH4 Codec Name C-Media CMI9739A/9761 Codec ID 434D4983h S/PDIF Output Not Supported Chipset Manufacturer: Company Name Intel Corporation Product Information http://www.intel.com/products/chipsets Driver Download http://support.intel.com/support/chipsets Driver Update http://driveragent.com?ref=59
click on the link adjacent to Driver download and it should take you to a site where you will find appropriate drivers for your audio controller.
download and install the drivers and that shoul do it
Good Luck!
Feb 26, 2009 | Acer Computers & Internet
Audio problem No proper sound
your motherboard and sound is not compatible with vista? there are no drivers for vista for your sound device.
try other drivers from this link. maybe the windows 2003 will work?
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=661FX7MI-RS&TypeID=en-us0000004
Feb 24, 2009 | Foxconn 661FX7MI-RS (661FX7MIS)...
EliteGroup 661FX-M Motherboard Logo
113 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
