Question about HP ProCurve Switch 2650
Hp ze4600 will not power on
When I plug the adapter in the yellow charging light is blinking. Press the power button and the blue power on light just blinks at me like it is in standby or hibernating and wont wake up.
I can hear faint electrical humm from the motherboard. I tested the Adapter it tested fine and I tested the fuse on the motherboard also tested fine.
I have removed the cmos battery/all the drives battery etc. still it appears to be in sleep mode.
I have taken it apart and reassembled it 4 times and cannot see any burnt spots on the mobo.
    Habit-Forming:
    New Friend:
  • 64 Answers
Hello Mimmerfy, I have just read your problems, you checked almost every basic points. you should also read this link for more diagnose your computer issue:
If you didn't get answer recommend to call me at +1 (833) 493-0111 (toll-free) number.
Cheers
John
Posted on May 03, 2017
SOURCE: HP Pavilion Laptop zv5000 wont power on. NOT power cord problem.
Do you have Vista? If so, you should contact HP directly. I had the same problem which occured 3 months after my warranty ran out. I called HP and was told(after they tried to sell me another laptop) that I installed the wrong antivirus program but since I never used my warranty, they would do me a BIG favor and fix it for free. I then waited 14 days for my new laptop and was very happy when it was returned only to find out 3 months later that there is a RECALL for HP laptops with the Vista program that was a MANUFACTURERS defect. THEY HAVE TO FIX IT AND FOR FREE!!!!! I hope this helps you. Good luck.
Posted on Feb 28, 2009
RSBennett
  • 54 Answers
SOURCE: Sleep Mode Lockup on Dell Inspirion 530 w/ Vista
Try hitting the "Windows" key on your keyboard to bring it out of sleep mode. The "Windows" key is generally found on the bottom row of the keyboard, near the Alt and Ctrl keys, and it has no letters on it, just the Windows logo. That key brings my Windows Vista machines out of sleep mode when other keys won't.
As for the power button, anytime you need to force a computer to turn off, you can press and hold the power button to do so. Usually, you need to hold the power button for 5-10 seconds and it will shut down. Use this option with caution, as it turns the computer off without running through the shutdown process and can cause you to lose data.
Hope this helps.
Posted on Mar 08, 2009
  • 33 Answers
SOURCE: HP Pavilion dv4000 battery won't charge
all you really need to do to find out if it might be broken is to check and see if that DC Jack on the computer is "wiggling" around, if the center part is moving around. If it is, then there is a chance that it is broken. I used to work at a computer store where the owner would resolder new DC power Jacks into laptops, but he was the only one in town who did that. So you might want to check around at the local computer repair or electronics stores to see if someone does that type of thing. Also, have the power supply checked out, it could just be dead.
Posted on Mar 25, 2009
joecoolvette
  • 5660 Answers
SOURCE: dv6000 443775-001 power issue
At the risk of subjecting myself to your possible wrath, I suggest you replace the motherboard. I don't know your computer repair prowess, and am not doubting it for a minute, but I 'stand' here to tell you, that it's just not that simple.
The hardware components are installed down into a bare motherboard. The leads for the hardware components are in their 'raw' state, where they hang down past the motherboard. Then the motherboard is heated up using a hot air soldering method, and the solder flows over the leads making a precise, pretty little solder joint. This is done with robotics. Once this is accomplished, the extra length of lead is snipped off.
Some components are installed by hand. Very few of them. The operator uses a soldering station, and an instrument that magnifies the area by a great amount. Looks like a binocular microscope. One, two ,three, and the next motherboard comes up, and the same part, by the same operator is installed once more.
Again, not doubting your expertise in this area, but if you have use much heat, or linger too long, you stand the chance of making the copper circuit trace, lift right off of the motherboard, when you go to remove a component. Not enough heat, and you can't remove enough solder, nor get the lead to come out of the hole. (I use solder wick. Also known as Desoldering Braid. Solder ****** tools are for the bird's! (Desoldering Tool)
Same thing with soldering a new component in place. Too much heat or linger too long,....well you know what happens. Not enough heat, or staying in position long enough, plus using the right technique, you get a cold solder joint. It's a lot of fun, when you reassemble the laptop all the way, and find this! Guess what happens next? Yep! Do it all over again!
I'm not a saleman for Ebay, but I find a lot of my motherboards for laptops on there. I would also suggest looking at -> Laptops for Parts.
Posted on Apr 14, 2009
  • 52 Answers
SOURCE: HP Pavilion 8000 power light and battery light blinking
hi,
Hp recalls some king of batterys, maybe yours it is on this recall, contact hp web or phone to take advantege of this recall, otherwise appears that your battery do not work you may replace it.
Thanks
vcrtech
Posted on Apr 27, 2009
How do I solve a problem with my Hp Probook, whenever I press the power button, the power light flashes nine times?
On that particular model you need to press the power button nine additional times waiting for the light to Blink 9 times each and then after the 9th time the procedure is as follows... Press the button 4 times hold for seconds on the fifth button push then release for 4 seconds then press the button twice and it should blink 8 times repeat this procedure continuously until the button only lights up once. After the button lights only once then you are ready to place the item into a garbage bag and throw it into the dump
Feb 08, 2018 | HP Computers & Internet
Elite book 2640 blue light light on,yellow light flashing,screen blank
yellow light sounds like charge indication.If you press the power botton the fan should spin and you should be able to open the DVD by pressing the button on the tray.These are 1st steps to check motherboard function.If there is RAM installed remove battery after turning off power supply.Open memory door and reseat RAM.Replace cover then battery - power on.Any picture?Try an LCD monitor - no picture? Try different RAM or 1 stick at a time,remember to remove battery or RAM will be damaged.Still no picture - remove battery and try with AC adapter only.Still no picture - remove AC hold down power button for 30-sec plug in AC only and press power button.Still no picture - check CMOS battery if it uses a CR2032 button cell it may be flat.This can cause a no boot situation.If the CMOS has a plug or is soldered to the board that should be OK.The button cell may be hidden in the chassis anyway and to change it will require disassembly.So replace it when doing the cleaning.Still no picture - GPU is faulty.The unit should be disassembled and a reflow of GPU done,as well as cleaning all dust and fluff from the fan and other cooling system components.Airflow restriction of the cooling system is the cause of overheating and GPU issues.Google disassembly for your laptop and reflow method for GPU.If you have no experience with disassembly a step by step guide is crucial.Breaking parts is easy so extreme care is very important.
Apr 10, 2014 | HP EliteBook 6930p Notebook PC
Laptop hp compaq tc 4400 is not charging , during adapter connected to laptop and turning power/standby led ... it doesnt switches on, instead battery charging led blinks 4 times, and doesnt turns on, so...
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 16, 2011 | Compaq tc4400 Tablet PC
Basically i plugged in the ac adapter to it, pressed the power button and the power light comes on for 2-3 seconds then the power light shuts off. lcd screen never turned on or show anything, fan never...
>>> Please leave feedback so I can continue helping You & Others
The middle blue led is the charging indicator, sounds like you have (at least) a bad battery, remove it, plug in AC and try again, if no good, remove the HD and repeat, if no good, remove/replace the ram and repeat, if still no good, your mainboard is cooked.
Thanks,
Adam.
Feb 19, 2011 | HP Pavilion DV9429US Notebook
I cant turn on my HP520 notebook pc. when i press the power button, it blinks once, and the charging light blinks for 9times(orange light, the 8th times was green light) i tried to remove the battery and...
Alright, not sure if this will help, by my understanding is that you are saying that when you power the computer using the power supply adapter, nothing comes on? Then when you have your battery installed on, then there are lights blinking from your battery charger LED amount of times. In this case there are no promblem with your laptop and it is your power supply adapter that is damaged and will need to be replaced. It is not charging the battery. The battery is still good, but does not have enought charge to power up your system. You can find a charger on ebay for a good reasonable price compare to getting it from Hp. I hope this can help you.
Jan 13, 2011 | Computers & Internet
My power cord is OK and a blue light is seen where it plugs in. However, I can't turn it on. I had it on a few times yesterday and the battery check says battery is "good". However, battery is at 0%...
I have had this issue with a few HP laptops.
Does the lighning bolt light up on the laptop to indicate charging?
Maybe try unplugging the power adapter and battery, press and hold the Power button for 30 seconds, pug in the battery and power adapter. In Windows click Start > Settings > Control Panel > Power Options. Click on Power Meter Tab and check the startus of the battery (i.e. Charging, not present etc)
Aug 23, 2010 | HP Pavilion dv9000z Notebook
Laptop will not start up at all. The led next to the power jack lights blue nothing happins when i hit power.
When you press the Power button do any of the lights Flash or blink?
1.May be try removing the power adapter and battery, press and hold the power button for 30 seconds and try again.
2. Connect the power adapter with no battery
Aug 23, 2010 | HP G70-246US Notebook
Computer won't power up
If the blue ring on the AC IN is lit, there are some things you need to check to see where the problem is.
1: Does the computer come on with the quicktouch buttons?
2: Does the computer come on using the remote? Verify the remote battery is good too.
(point remote at Digital Camera and press power button, you should see it blinking in the viewfinder)
If the blue ring does not light up. Check Adapter
If using a generic adapter and the power light on the adapter goes out when plugged into laptop- it is a shop repair.
Another item that could prevent from coming on is the ribbon cables to the power section, but that is only if the laptop has been opened and attempted repairs previously.
Apr 20, 2010 | HP Pavilion dv9000z Notebook
Toshiba Satellite A60 wont power up
It looks like some divece in your laptop dont pass POST test. Tech support from Toshiba required
Sep 23, 2009 | Toshiba Satellite A60 Notebook
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
HP ProCurve Switch 2650 Logo
246 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
