Kitchen Ranges Logo
A
Anonymous Posted on Sep 15, 2014
Where to buy a electronic oven control/clock part for my kenmore range model 970-602620
Kenmore kitchen ranges model 970-602620
Ronald Rissel
Level 3:
Master:
  • Kenmore Master 715 Answers
  • Posted on Jan 27, 2015
Ronald Rissel
Kenmore Master
Level 3:
Master:
Answers
715
Questions
Helped
259064
Points
1075
Go to SearsPartsDirect.com
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
5 Related Answers
Anonymous
  • 413 Answers
  • Posted on Jun 26, 2008
SOURCE: Kenmore range model 790.90152300 the
The electronic oven controller has failed. The cost is around $160.00.
Anonymous
  • 8619 Answers
  • Posted on Aug 10, 2009
SOURCE: F1 error message Kenmore Electric range model 790.95680301
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Anonymous
  • Posted on Mar 26, 2010
SOURCE: New Electronic Oven Control does not work, Kenmore model 7909634
our top elementes work but the oven and the display don't . All fuses are good and nothing looks burnt. Some smoke came from inside the oven but the elements look good.What's wrong?
machinetech7
Jason Kennidy
  • 1344 Answers
  • Posted on May 28, 2012
SOURCE: Kenmore range electronic clock blew twice.
If you blew two boards in that short period of time then you have some other issues going on, and from the sound of it its not the machine but the power supply coming int.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
rbheaton360
randy heaton
  • Posted on Nov 07, 2013
SOURCE: Kenmore Range/oven Burners won't lite
Anyone know how to remove the cavity of a kenmore elite range? it expanded during the self cleaning and now it's to big for the racks.
Electronic Oven Control on my Kenmore 95321range is not working
I just replaced mine and it's an easy fix even if you're only moderately handy. You'll need to purchase a new or refurbished oven control board. This generally is just the internal components and does not include the overlay, if any, for the clock. This will depend on your model. Here's a video showing you how easy it is.
When I plug my stove in i have the burners that come on but the oven and the clock and timer part doesn't light up. the oven doesn't come on either. My model # is J B P 76G S1WW
This indicates the ERC Electronic Range Control has failed. Check to see if you have power going into the control. If you do and nothing is working the control board or ERC needs to be replaced. Here is a link for checking and replacing an oven control. If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
2answers
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 • Ovens
F-11 comes up when using oven.
F-11 refers to Shorted Keypad.
Disconnect the Power for Few minutes, say 5 minutes, and then Power ON the Kenmore Gas Kitchen Range.
If the Error Still remains, Replace EOC ( Electronic Oven Control / Clock ).
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
1helpful
3answers
Self-cleaning electric range
Hi
Here are the codes for you range:
F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1Safety flip flopReplace Electronic Range Control/Clock (ERC) F2 - E0Shorted keypadReplace Electronic Range Control/Clock (ERC) F3 - E0Oven temperature sensor or oven temperature sensor fuse openedReplace oven temperature sensor or fuseF3 - E1Oven temperature sensor shortedReplace oven temperature sensor F3 - E2Oven too hotReplace oven temperature sensor F3 - E3Clean temp too hot Replace oven temperature sensorF5 - E0
F5 - E1 and E2 Door latch problemCheck door/latch switch, replace if necessary
Looks like yours is a bad oven control. There is a # at the end of yourmodel # 0-5 that will determine which control it takes. Once you havethat # you can look it up at http://www3.sears.com/ Looks like the part costs about $165.
JKenmore Range
hi. thanks for the question. the fi failure code says to replace electronic oven control. sorry . thanks the appliance doc
F5 code displays
First turn the breaker off to the oven and leave it of for about 10 minutes. This will reset the clock and if the erc (electronic range control) is still good it will reset and work. If it doesnt come back on replace the ERC. You can order the part from sears via model number.
1helpful
2answers
Kenmore electric range 911.9369181
F8 Failure of Electronic Range Control (ERC) Replace Electronic Range Control/Clock (ERC)
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
BEEPING OVEN
The F1 and constant beeping is an error code indicating that your electronic control board (clock/timer) is defective. The fault cannot be reset and the control board must be replaced. This can be an expensive repair if your range is no longer covered by a warranty or service plan. The cost to buy a new control board can be in the neighborhood of about $200. Sorry...but I do hope this helps you.
Top Kenmore Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
