Question about Microtek 3630 ScanMaker Scanner
Yellow lines when I scan anything, I get yellow lines down the sides of the document. If it goes to the printer or to an application, I get the stripes of yellow. Is there a fix or download? Thank you onion129 Same problem yellow lines.
  • 2 more comments
  • dizzydog Nov 10, 2007
    No I tried that.
    It's a microtek scanmaker 3740
    But thanks anyway
  • dizzydog Nov 11, 2007
    The scanner is a microtek scanmaker 3740.
    I tried updating the drivers
    It didn't work.
    But thanks anyway
  • dizzydog Nov 12, 2007
    funny how my scanner worked fine
    until last October when I installed SP2
    then the bulb is going
    the yellow lines only occur
    in colored scans
    black & white is still fine
    thank you for all the info
    I did re-install the drivers in safe mode
    still no luck
    but thanx
  • Anonymous Dec 04, 2007
    Yes on my HP 7310. After an aggravating 3 hour "chat" with an HP tech support person it was finally diagnosed as a scanner bulb problem that was either faulty or not getting enough power (???) I was told it was not replaceable/ repairable and then they tried to sell me a new machine for 20% over Amazon pricing. Go figure.
    I don't buy that it's not repairable/replaceable. Anybody know anymore?
  • 1,601 Answers
It sounds like you have a corrupted scanner driver . Please uninstall and reinstall.
Here are the drivers
Posted on Nov 10, 2007
Samsung CLX-6220-FX vertical lines when scanning and copying
The reason for such lines if they appear only on scans/copies from the automatic document feeder (adf), but not on regular scans and printouts is that there is dirt on the small glass stripe next to the scanner area that is used for scanning from the adf. Just clean that glass stripe and the lines should go away.
Jan 21, 2014 | Samsung CLX 6220FX - multifunction fax /...
Yellow Stripe Down Middle of Screen on Laptop
This system has a VGA port so you can plug in an external monitor. You can buy one for less than $130 based on the Sunday ads. Other than that, it is new laptop time.
Jul 31, 2010 | Acer Computers & Internet
Why are there black lines down the centre of my faxes
This can be due to some dust on the scanning apparatus. Simply try blowing it out. If it will not help, it is probably defective, however it rarely fails completely. On scanners it sometimes does yellow stripes. It usually comes with older devices.
Apr 14, 2010 | HP OfficeJet 6310 All-in-One Printer...
Red/yellow line down left side of document when using feeder
the solution to this issue is cleaning the scanner glass below the automatic document feeder(mind you its not the scan bed that you normally use while copying) .you will get the ADF scnner glass once you lift the ADF door,you will see a 1 inch wide scanner glass.that is what you need to clean.
If you want any further support a technician can help you online for free.You can find free online technical support at
Jun 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Black stripe down center of document
as you have cleaned the scanner glass..try these steps..
1)connect the printer to the wall outlet..
2)then try to make a copy..if you get lines..then go to next step..
3)unplug the power and hold OK and CANCEL button together..while pressing the buttons plug in the power chord..
4)after you plug in the power chord do not release the button till the screen goes blank..once its blank release the buttons and then turn on the printer..
5)try to make a copy..its still the is a hardware issue..machine should be replaced
6)Call HP who would give u a rebate on old printer & replace it with brand new printer.
Mar 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Black line down the middle of scanned documents.
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.  You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
Jan 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
White line down side of page when scanning
If this is happening only when you are scanning using the automatic document feeder, check for something blocking light above the scanner. If you open the scanner top, look along the left side of the scanner glass where the paper is scanned by the automatic document feeder. If you see anything on the glass there, clean it with a soft cloth dampened with clean water.
Jun 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
532 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
