SOURCE: Xerox phaser 7760 streaking
to fined out what the problem could be you need to open a word doc and sent a blank page to the printer. from this it will show where the problem is in the printer
if u still get streaking it couls be a faulty toner and it may not be the cyan toner either. i would give the fuser unit in the printer a check. if there marks on tthis unit i can cause this problem as well
SOURCE: how do ya reset fuser code (H-4) Xc1044 Xerox?
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
SOURCE: i have blocked the fuser uit
All you have to do is open the fuser unit on the end (2 Screws) and you will find a fuse which has 3 strips (in a plastic casing with wires attached). You must the solder the strips so that they are joined, and that should reset the fuser.
SOURCE: hello i hope someone can help me with my problem i
You can get more life out of the fuser by removing one end and placing a piece of tin foil OVER the THREE FUSES, which are designed to blow at set times. Just tape it in place with some tape.
Good Luck
SOURCE: How can I reset the Xerox Phaser 3100MFP fuser?
A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without any problem. www.nakshatraworld.com, 09713862555
