2003 Oldsmobile Alero Logo
Posted on Jul 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Service engine soon light is on - 2003 Oldsmobile Alero
  • Anonymous May 11, 2010
    when was the last time you serviced the car? Usually tells you to change oil before service engine soon.
    may be timingbelt service what milage is it
Anonymous
Level 2:
  • Expert 66 Answers
  • Posted on Jul 16, 2009
Anonymous
Expert
Level 2:
Answers
66
Questions
Helped
27519
Points
189
How to reset (erase the light):
Open the fuse access panel on the driver side. Youll see a small rectangular red button labeled RESET.
Turn ignition ON
Press the RESET button repeatedly until you see the SERVICE ENGIN light flashing on the dash.
Press and hold the RESET button for a few seconds until you hear 5 'dings'. It will turn off.
Turn ignition OFF.
Drive safely.
Good luck.
Please rate the solution....
3 Related Answers
honeymokey
honeymokey
  • 3113 Answers
  • Posted on Jun 17, 2009
SOURCE: Grand Am 2003 "service engine soon" light
The service light means something is wrong with the car and it needs attention now. Get the codes checked and that will tell you what is wrong with it.
REDOIL
Earl Norager
  • 355 Answers
  • Posted on Oct 14, 2009
SOURCE: service engine soon light
NO THEY ARE THE SAME SOMTHIG IS WRONG
david balderston
  • 437 Answers
  • Posted on Feb 10, 2011
SOURCE: "Service engine soon" light came on, how soon is
have it scanned then decide depending on the code
tip
A service engine soon light that flashes generally results form an ignition problem with the engine. A service engine soon light that stays on constant results from an emission control system malfunction. A diagnostic scan from the local parts store can determine which emission system is faulty.
2000 grand am gt. Check engine light is off but the Service engine soon light is on. There are no error codes. I have already changed the oil and reset the oil light.
Service engine soon ? Do you mean SERVICE VEHICLE SOON Indicator
The amber SERVICE VEHICLE SOON indicator is an alert to the driver whenever there are specific current codes stored in the BCM or in the event of a loss of Class 2 serial data.
If your vehicle has a check engine light ,it doesn't have service engine soon .One or the other .
What does the service engine light mean on a 2015 Ford Edge
Service Engine Soon
If the Service Engine Soon indicator light stays lit after you've started the engine, the On Board Diagnostics system (OBD) has detected a malfunction of the vehicle emissions control system. Contact your authorized dealer as soon as possible.
If indicator light is blinking, an engine misfire may be occurring, which could damage your catalytic converter. Drive in a moderate fashion (avoid heavy acceleration and deceleration), and have your vehicle serviced immediately.*
The Service Engine Soon indicator light illuminates when the ignition is first turned on (prior to engine start) in order to test the bulb, as well as indicate whether the vehicle is ready for Inspection/Maintenance (I/M) testing.
Normally, the Service Engine Soon light will stay on until the engine is cranked, then turn itself off if no malfunctions are present. However, if after 15 seconds this light blinks eight times, it means that the vehicle is not ready for I/M testing.Check this link out Gary.
https://owner.ford.com/how-tos/vehicle-features/dashboard-instrument-cluster/warning-lamps-and-indicators.html
I have a 2001 mustang bullitt that is showing service engine light on. Took it to mechanic and he put 2 different machines on it to show code for problem. No codes coming up and he can't turn off the...
There is a diagnostic procedure in the factory service repair manual for engine light lit ,no codes . Did you take it to ford dealer ? MIL - is referring to check engine , service engine soon etc...
  • MIL always on when engine is running (no DTCs):
  • MIL circuits
  • For Focus, Mustang, Town Car, Continental, LS6/LS8, Escape, Windstar, F-150, Expedition and Navigator/Blackwood:
  • Instrument Cluster, Section 413-01 of the Workshop Manual.
  • All Others:
  • GO to NB1
SERVICE ENGINE SOON indicator After the engine is started, the SERVICE ENGINE SOON indicator will prove out for a duration of three seconds. If the instrument cluster does not receive a message from the PCM within five seconds, the instrument cluster will illuminate the SERVICE ENGINE SOON indicator and log a diagnostic trouble code (DTC).
  • An indicator is inoperative/always on - SERVICE ENGINE SOON
  • Circuitry.
  • Bulb.
  • Instrument cluster.
  • PCM.
  • GO to Pinpoint Test P .
PINPOINT TEST P: AN INDICATOR IS INOPERATIVE/ALWAYS ON - SERVICE ENGINE SOON CONDITIONS DETAILS/RESULTS/ACTIONS P1 CARRY OUT THE INSTRUMENT CLUSTER SERVICE ENGINE SOON INDICATOR ACTIVE COMMAND Trigger the HEC active command MIL.
  • Did the SERVICE ENGINE SOON indicator illuminate?
Yes REFER to Powertrain Control/Emissions Diagnosis (PC/ED) manual.
No INSTALL a new instrument cluster; REFER to Instrument Cluster . CLEAR the DTCs. REPEAT the self-test.
1helpful
2answers
The service engine soon could be an indicator that you need to have minor maintenance done in the near future. I had a Grand Am that the service engine light would turn on when I was getting close to needing an oil change. You might check your owners manual for an exact reason as to why it turns on.
2answers
Lincoln town car + service engine soon
Service engine soon has nothing to do with service or maintenance . Emission's OBD 2 engine managment system . Light on ! DTC'S - diagnostic trouble codes stored . Your don't know THAT ! Your best bet , take it to the dealer .
14helpful
2answers
"service engine soon" light on
should have two lights check engine and service engine soon.check engine means there is a malfunction.service soon is reprogrammable,when you change you oil. check you owners manual for reset.
I’m happy to help further over the phone at https://www.6ya.com/expert/kenneth_3efc1f8510674f04
4helpful
I have a 2001 Oldsmobile Alero. What does it mean when the anti brake light, service engine soon, and traction off light comes on at the same time?
I am assuming its not the service engine soon light it is probably the service vehicle soon light, There are 2 lights service vehicle soon upper left side, and service engine soon upper right side.
When all these come on at the same time it is the wheel bearing sensor. Usually the wheel bearing needs to be replaced which houses the sensor. A sure way to check is to press your sls button by your shifter and see if the light goes out, If it does not, u will need to have a wheel bearing put in.
2helpful
Two service engine lights
one is service engine soon referring to the engine and trans. systems, and one is service vehicle soon, referring to body, abs, hvac, etc. systems two different lights for 2 different types of trouble codes
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you an Oldsmobile Expert? Answer questions, earn points and help others
