Question about Goodman CLJ36AR42 Air Conditioner
I have a Goodman air conditioner. My outside unit
I have a Goodman air conditioner. My outside unit is not running. The unit is getting power, the fan is not turning
  • Anonymous Mar 15, 2014
    What size tonnage
I HAVE A 410A GOODMAN 3.5 MY CONDENSER PSI IS GOING FROM 400 TO 550 WHAT IS THIS
Posted on Jul 21, 2010
  • 4 Answers
I had the same problem, it was the capacitor. Check out http://forum.doityourself.com/archive/index.php/t-99833.html
Posted on Jul 03, 2009
    Sergeant:
  • 340 Answers
If you are sure of the power then ya have a control problem thermostat set correctly? could be open low pressure switch I would call for service. Tom
Goodman Model CPLE24-1C - Two Units. One unit works fine, second outside unit will not engage.
It sounds like the run capacitor(silver can in control box) has failed if your comfortable around electrical you can change it; just replace it with the same rating as your other one. Make sure the power is off and write down it rating (i.e. 35+5 370 or 440 volts for a dual or 35 370 or 440 volts for a single).
Jul 08, 2012 | Goodman CPLE24-1 Air Conditioner
My air conditioner will not run, the fan will not run in auto or in run mode, the compressor will not start. The thermostat clicks on but the air unit does not. this is a Goodman cplj18-1b unit.
Hello, if the outside unit is not running check tje power supply to make sure you are getting 240 volts, also make sure the contactor coil is receiving 24 volts, if you are not getting 24 volts at the contactor then it may be a bad thermostat, control board or the thermostat wiring is loose or perhaps cut somwhere. If you have 24 volts at the contactor and does not energize than replace the contactor coil.
May 12, 2011 | Goodman Heating & Cooling
A/C fan is running but no cool air
Make sure the outside unit is running. If it is then you may need to get the unit charged.
May 02, 2010 | Goodman CPLT24-1 13 Air Conditioner
Goodman A/C won't cool
Fan motor or capacitor has gone out. Running the unit with the motor not running can cause damage to your compressor
May 01, 2010 | Goodman CKL24AR24 Air Conditioner
Fan on the outside unit is not running
Fan motor is dry or going bad try to lubricate it and see if that frees it up. If not you will need to get a new fan motor.
Oct 09, 2009 | Goodman CKL36AR36 Air Conditioner
Goodman outside unit not kicking on after power outage
If the outside fan works ,try to put a booster cap. in parallel with the capacitor , but if nothing works check the outside power supply box (or discennect) to see if a fuse is blown.
Sep 27, 2009 | Goodman CLQ36AR49 Air Conditioner
The air conditioning unit outside is running but there is no cold air coming into the house. I hear the inside unit turning off and on but no cold air. I also smell a burning odor. I have turned off the...
if unit is going on then off within a few minutes needs service can be needing freon,outside dirty causing overheating,power supply if 220 not getting full power ,to compressor going bad
Sep 26, 2009 | Goodman CLQ36AR49 Air Conditioner
Not running outside
You may not be getting power to the contactor to the outside unit. Look for broken wires. Usually small in diameter. Dogs and critters love to chew on them.
Good Luck and hope this helps.
Apr 26, 2009 | Goodman CKL24AR24 Air Conditioner
Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Jun 26, 2008 | Goodman CKL60AR60 Air Conditioner
Goodman CLJ36AR42 Air Conditioner Logo
567 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
