Question about Air Tools & Compressors
My 5 hp, 25 Gal. Craftsman air compressor is blowing a lot of air out of the muffler and little into the tank. I dismantled, cleaned and oiled the head and it seems a little better but still won't pump up pressure. Any suggestions?
  • mikexxxx Jul 04, 2009
    The model No. For the compressor which is blowing air from the muffler is 919.165250. I checked the sears site but didn't see an intake valve. Thanks for your help. MMG
  • 234 Answers
It sounds like your intake valve is worn or defective. Take the head apart again and look to see if the valve is sealing properly. If you post a comment with your model number I can look up the specific parts at sears parts.
If your compressor is functioning properly, air should not come out of the intake muffler (filter)
Thanks,
Tim
Posted on Jul 03, 2009
I used compressor 3 wks ago and worked great.Now will not compress air above 25 psi.changed regulator OK,removed air intake filter,it has suchion.removed outlet tube,bloweds air.Oil in site glass.I did...
Mike:
If you have air blowing out of the oil filler cap, I would suspect that the piston rings are shot. The piston rings are supposed to keep the compressed air above the piston, and air seems to be leaking past the piston rings into the crank case.
Sep 17, 2013 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman Air Comp. 6 hp oil-less, 33 gal horz. tank - sounds really loud
Some of the craftsmen compressors have pistons that are coated on the top of the dome. Once the coating wears off, they have severe loud piston slap. If you continue to run it the way it is, it will snap the connecting rod in half or break the piston and possibly the cylinder.
Sep 21, 2017 | Craftsman 33 gal Air Compressor 6 hp...
The tank fills with air, but the motor doesn't shut off. It continues to run.
Pressure switch is stuck on, dont use this until its fixed!!!!!, you could overfill the tank with excess air, it could be adjustable or the switch may need cleaning/replacing.
Mar 09, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
Is there supposed to be water in the air tank?
yes it will build up. the compressor get very hot.you should drain every day. and have a good water seperator prior to your tools.
Feb 19, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
Compressor runs to 175psi but trips pressure relief when pressure drops tries to restart motor but motor wont turn blows breaker. changed whole pressure switch have same problem.
The problem is lilkely the check valve between the compressor and the tank -- it is alowing pressure to build from tank to compressor preventing the compressor from turning over. Clean, maybe replace, check valve...
Charlie
Jan 09, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
Air Tools & Compressors Logo
1,681 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
