Home | Dometic | Rooftop RV Air Conditioner | THERMOSTAT TURNS FAN ON ...
Dometic Rooftop RV Air Conditioner
Problem for Dometic Rooftop RV Air Conditioner
THERMOSTAT TURNS FAN ON AND OFF, BUT COMPRESSOR
By jm43130 on Jul 03, 2009
THERMOSTAT TURNS FAN ON AND OFF, BUT COMPRESSOR WILL NOT COME ON. JUST BOUGHT TRAVEL TRAILER USED. OWNER SAOD HE THOUGHT A FUSE NEAR COMPRESSOR ON ROOF.
Sponsored Links
Solution #1
posted on Jul 03, 2009
Not Rated)
jeffmyers_20
Rank: Guru
Rating: 96%, 66 votes
There is no fuse near the compressor on the roof. The only thing on or near compressor is the thermal cutoff switch either located on the top of the compressor or the side (depending on the model). You can check the thermostat rather easily with a 12V Test Light (available at most automotive stores) or a voltmeter.
Take the face plate off of the tstat. You should have a 6 wires or so (again, depending the model or part number of the unit and the tstat). If you turn the thermostat to high/cool, the yellow from the thermostat should have power to it. This is the cool setting. If there is no 12V going to the yellow wire, then you have a bad thermostat. If there is power, then you need to get up into the control unit of the AC and see if you have power at the yellow wire there. If you do not, then there is a problem in the wiring in the wall. If there is power, then you may have a bad control board.
There is a relay on the control board that controls the compressor. If you turn the unit to High/Cool and you do not hear the relay clicking, then you have a bad board.
You may want to get a tech to take a look at it, it can get complicated.
Hope this helps,
Jeff
Was this helpful?
Yes
No
Solution #2
Not Rated)
taa43
Rank: Guru
Rating: 85%, 196 votes
Now the owner He's smiling, I asssume it is an older unit make sure the t-stat is set properly.cooling likely compressor issues could be start components or bad compressor get qualified service Good luck Tom
Was this helpful?
Yes
No
Popular Solutions for Dometic Rooftop RV Air
Questions and Unsolved Problems for Dometic Rooftop RV Air
Do you recommend Dometic Rooftop RV Air Conditioner?
Answer
Answer
I am trying to find the specifications of my Dometic Quick Kool Duo Therm Model 80611442 - its on a... (More)
Answer
I have removed the interior bracket and outside I have removed the shroud. What is next? This is a... (More)
Answer
had loft conversion, problem on inside of picth roof where roof meets floor gets wet and patches... (More)
Answer
Dometic 630516.331, frequency spikes with both A/C & Heat pump
Answer
need thermostat wiring diagram for duo-therm heat strip
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dometic Rooftop RV Air...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
