Question about Hitachi 42HDS69 42 in. Plasma Television
Pip problems i cant seem to get the pip feature to work i have a hd dvr cablebox connected which connects via component cables or hdmi and a playstation 3 connected via hdmi and when im watching either and i click pip on the tv remote the second pip is blank with the cable input highlighted and i cant switch inputs
3 Suggested Answers
SOURCE: Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Posted on Nov 20, 2008
  • 108 Answers
SOURCE: No sound on NON HD channels
Check menu on tv and see if the audio input has any other settings. May have different options for sound processing.
Posted on Jan 06, 2009
  • 1077 Answers
SOURCE: Hitachi 50V720 No sound with HDMI - no Component video inputs
Right now there seems to be many people with the same TV problems with sony and HDMI cables. Most of the solutions are resetting the TV and sony product. Try leaving your TV unplugged for a hour to let it reset itself.
Posted on Feb 17, 2009
0 characters
1 Points
All hdmi connections not working on a samsung ue40c8000 every thing else seems to be ok. done a factory reset does this sound like a new board costly? regards. Norman
The tv Samsung refurbish main tv Turner signal board will set u back like $120-130 bucks + shipping and handleling and u must have to have some basic mechanicals skills like take things aparts and putting it back togther again to fixed this tv just for the used of those HDMI hubs ports again.My questions to u is?Does ur tv used 100% must require those useages of those HDMI hubs ports.Not just used the Samsung tv as is.My Samsung tv have the same problems.I just work around it by skipping all the useages of all those HDMI ports hubs of the tv altogther.Most poeple just used about like 3 HDMI ports hubs for like a HD cable box or DVR cable box and a PS3,WII games systems or Blu Ray DVD player.All these devices can go through hook up for like a RCA component cables hook up like AV1,AV2 and last one a HD hookup by a RCA component cable just add 2 more components wires like a green and purple connections or just buy a set of RCA components cable that design for a HD output.I did that,must more reliable set up too.Because those RCA components cables set up have more plastics in it connections for insulation holes for little shorts and sparks better than those HDMI ports hubs and HDMI cables barely help and the plastic for insulation is a joke almost non exiten.Those all dam HDMI ports hubs are all link into one path way on the circuit board,one dies or got shorted all dies and get shorted out.
Aug 14, 2011 | Flat Panel Televisions
PIP function does not work, the settings is greyed out also! I have a wii, PS3 and freesat :)
Hi nikkicollier,
PiP for your TV works between two different sources. This means between a component source and an HDMI source or between an HDMI source and another HDMI source. PiP also works with a PC connection, e.g. when using the TV as a computer display. PiP does not work between two component sources. The setting will be grayed out when you don't have a configuration that is supported, as the Samsung TV's are usually able to automatically detect which sources are plugged in and available.
I'm not exactly sure what sort of configuration you want your PiP to work in, but try one of the following configurations.
  • TV Cable (through VCR or other via Component input) with Satellite in PiP (via HDMI input)
  • PS3 (via HDMI Input) with Satellite in PiP (via Component Input)
  • Wii via HDMI Input) with PS3 in PiP (via HDMI Input)
You can usually find an HDMI cable for much cheaper at an electronics supplies shop, Radio Shack, or on eBay or Gumtree.
To change your PiP settings:
  1. Press the MENU button on the remote control. Select Picture and press Enter.
  2. Select PIP and press Enter.
  3. Press the enter button again, and press up or down to change the setting to On and press enter again.
    If PIP is activated the screen will display in widescreen (16:9 aspect ratio.)
  4. Press the up or down buttons to select the Source then press the Enter button.
    Select the source of the sub-picture by pressing the up and down arrows and then pressing the Enter button.
    Note: The sub-picture can serve different source selections based on the what the main source is set to.
    You may notice that the picture in the PIP window becomes slightly unnatural when you use the main screen to view a game or karaoke.
You can download the full PDF manual for your TV here (large download at 26MB.) Much of the PIP information can be found on pages 13 and 14.
Good luck, I hope that helps.
Mar 01, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I needed to know how do connectd my dvd player with my tv and ditail cablebox form coxs
Dec 13, 2010 | Flat Panel Televisions
I have a samsung tv and samsung blu ray i have my dvr in hdmi 1 and my blu ray in hdmi 2. when i first turn on my tv and blu ray it works fine but if i switch to cable the back to blu ray it says no...
First, HDMI is not a perfect hook-up solution. Cable box connections via HDMI are notorious for being problematic. The best thing you can do is contact Samsung and get the latest firmware for your TV.
Samsung Customer Care: 1-800-Samsung (1-800-726-7864). If this does not resolve the issue, connect the cable box using Component cables instead of the HDMI. Component cables are HD also. I hope this was of some assistance.
Apr 07, 2010 | Samsung LN55B640 LCD TV
I have a toshiba 42 inch tv model number 42RV535U we have it connected to an HD cable box and the sound will periodiclly cut out for a second and come back on it will work fine for a few seconds and do it...
Access the cablebox setup menu if possible. If it is a Motorola, you need to have the TV on and turn the cablebox off. Then press menu on the cablebox or cablebox remote. Under HDMI options, change audio output to L-PCM or PCM. This may not fix the issue, but it is a good start. Secondly, contact Toshiba for the latest firmware update for your product. Some models have had new firmware releases as late as this week for similar issues. If you still do not find resolution with these two recommendations, you should switch to component (Y/Pb/Pr) cables for your connection.
Mar 14, 2010 | Flat Panel Televisions
Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
Dec 01, 2009 | Flat Panel Televisions
My menu says dtv Currently unavailable. How do I use the HD feature on my Olevia LT32HV
Do you have a High Definition cable/satellite reciever or a Blu-Ray player? Does your tv have a HDMI input or component or DVi or all of those? Most newer HD components use the HDMI connection. The HDMI connection is a single cable that has both video and digital audio together. The component connection is a connector with three rca jacks that are red, green, and blue. Audio is connected seperately with this connection via red and green rca audio jacks or a digital audio connector. The last is a DVi connector that is found on computers. Some older HD tvs and components use this connection. There are adapters available to turn a DVi connection into a HDMI connection. So if your TV does not have a HDMI connection but your HD reciever does you can use and adapter but you will not have any audio this way without using a seperate connector for the audio.
Sep 16, 2009 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
HDTV goes blank when connected to Fios HD-DVR or Fios DTV recvr.
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
Jul 23, 2009 | Flat Panel Televisions
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung LTP326w
After few years of service with different TV providers I have problem with my TV. Last night my Samsung LTP326W just did the same think on HDMI connector and no mater what you do it will not turn HDMI video... it's connected to Verizon/Motorola DVR I called Verizon and they promptly replace DVR and HDMI cable but it didn't help at all, also sometimes when you power on/off I get message: The HD Content Protection of your display has been compromised Please use the YPBPR outputs for your HD connection...
When I switch to component cable it works just fine.
Feb 09, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
Hitachi 42HDS69 42 in. Plasma Television Logo
73 people viewed this question
Top Hitachi Flat Panel Televisions Experts
Are you a Hitachi Flat Panel Television Expert? Answer questions, earn points and help others
