All it says is steam boiler over temperature, but my machine won't even heat up?All it says is steam boiler over temperature, but my machine won't even heat up?
You can't post conmments that contain an email address.
The error code F 161 on a WMF 1200S coffee machine typically indicates a problem with the water flow or pressure in the machine. Here are some steps you can try to troubleshoot and fix the issue:
Check the water supply to the machine to ensure it is turned on and the water pressure is adequate.
Make sure that the water filter is clean and not clogged.
Check for any kinked or bent hoses, and make sure that all connections are tight and secure.
Check that the water tank is full and properly seated on the machine.
If the machine has a built-in scale, check that it is properly calibrated.
If the issue persists, please check the WMF troubleshooting guide or contact the manufacturer for further assistance.
If you're not comfortable with troubleshooting the machine, it is always best to call a professional technician to look into the problem.
Just had same problem with my hotpoint wmf740 showing h20 and found an easy fix was to clean out the detergent draw thoroughly and just behind it.to remove tray was easy and it does say to do this regulary in the manual
SYMPTOMS When you start any of the programs listed at the beginning of this article, you may receive one of the following error messages:
One or more components are missing or broken. WMF graphics filter is missing.
Wmf graphics filter is missing.
CAUSE This behavior can occur if the Windows Metafile (WMF) graphics import filter is damaged or missing.
RESOLUTION To resolve this issue, rename the Wmfimp32.flt file: - Click Start, point to Find, and then click Files or Folders. - In the Named field, type wmfimp32.flt. - In the Look in box, click Local hard drives, and then click to select the Include Subfolders check box. - Click Find Now. - Right-click the Wmfimp32.flt file, and then click Rename. - Type wmfimp32.old. - Press ENTER. - Close the Find: Files Named Wmfimp32.old dialog box. - Reinstall the program.
