GE Profile Spectra JGBP90 Gas Kitchen Range
Problem for GE Profile Spectra JGBP90 Gas Kitchen Range
Oven Door Exploded
By sharon_sl_sm on Jul 03, 2009
I had used the oven for 10 minutes over an hour earlier. No one was in the kitchen when the oven door exploded. The glass flew everywhere and was even up on the kitchen bench tops. Emilia Oven about 4 years old but hardly used. I have looked on web and found repeated stories of such event with no common lead up event? Very strange. This lonly happened a week ago and a trades person doing some other work said he had heard of a spate of such events in recent months.
It is certainly a well kept secret as I think the companies could be liable if someone was in the kitchen and got glass in their eye. Certainly if they know it is a possibility and do not warn potential purchasers.
Best Solution
posted on Jul 03, 2009
Very Helpful)
Obertelli
Rank: Guru
Rating: 94%, 329 votes
This fault has occurred on a number of these ovens and I've seen it happen occasionally on other makes and models.
The explosion is spectacular, but is actually due to a safety feature as all modern ovens which use glass doors must use toughened glass. This is heat-treated glass which is resistant to most knocks, but when it does break it shatters into lots of small granules instead of sharp edged shards.
In use, heat makes everything on the oven expand a little and afterwards everything cools down and returns to normal size. The problem is that the glass and metals do not expand or contract at the same rate and so there's always the chance that the differential expansion between the glass door and the metal hinges can put enough stress on the door to make it shatter. The engineers who designed your oven knew this and will have tried to ensure that the hinge design could cope, but it may be that they didn't do well enough.
The other possibility is that the door has a manufacturing fault: when toughened glass is manufactured the glass gets a lot of stress built into it (that's why it seems to explode when it breaks). After the glass has cooled down in the factory every one is supposed to undergo a couple of simple automated tests which will either cause the glass to immediately shatter or will cause it to be returned to the ovens to have the excess stresses removed. Sometimes these tests are not fully effective at identifying the "bad apples".
I'd strongly advise you to contact the manufacturer of your oven as the door should not fail in normal use even beyond the warranty period. What you have suggests a design or manufacturing fault and you may be offered a free repair without admission of liability.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Somewhat Helpful)
allbrandappl
Rank: Wiz
Rating: 79%, 25 votes
make sure the oven isnt overheating before you replace the glass i have only seen this mostly during self clean cycle
Was this helpful?
Yes
No
Popular Solutions for GE Profile Spectra JGBP90 Gas
Questions and Unsolved Problems for GE Profile Spectra JGBP90 Gas
Do you recommend GE Profile Spectra JGBP90 Gas Kitchen Range?
Answer
Answer
GE XL44 burners work, oven does not, broiler does not. can smell gas a bit. how can I troubleshoot?
Answer
i have GE XL44 range. How long should i run self clean cycle
Answer
Can I take out the broiler ignitor and use it for the baking ignitor on my GE XL44
Answer
clock stopped working several weeks ago, now I cannot use self cleaning features
Answer
Have a GE XL 44 switching from natural gas to propane, how do i do this on the oven?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Kitchen Ranges Experts
Top Range & Oven Repairmen
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
