Question about Nokia Cell Phones
Nokia hs-36w headset battery replacement , is it possible ?
Nokia hs-36w battery replacement , is it possible please as when the charger is applied the blue just flashes once and does not charge. Regards Colin
I need a replacement Power pack 12V-3A 36W. Can you please tell me where I could get one from?
Cherryl, You could try local stores that sell computers and electronics, Walmart, the source, staples etc. Check the attached links,for power pack/charger, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Premium 4 8 1 7mm Replacement Power Supply Cord Laptop Battery Charger...
Genuine Asus LCD Monitor 12V 3A 36W Ac Adapter Charger ADP 36EH
Laptop AC Adapter 12V 3A 36W 1 7 4 8mm
Amazon ca power supply 12v 3a
Apr 28, 2016 | Computers & Internet
How to pair a nokia 5730XM with BH202\HS-36W bluetooth
switch on bh202,5730xm bluetooth and check for connect audio enhacement go into it search for new device you can see bh202 connect and use it...
Sep 23, 2011 | Nokia Cell Phones
Cannot pair
if you can pair this device go to paring mode by pressing the answer/end key and the volume up( +) key at the same time over 5 seconds until the blue indicator light lights up.
after do this try to paring again.
Jul 20, 2009 | Nokia HS-36W Wireless Headset
Cannot pair headset with phone
Morning
After i reset the headset, the passcode "0000" allowed the headset to pair with my phone.
Thanks for the info that was posted as it helped me solve my problem.
Aug 26, 2008 | Nokia HS-36W Wireless Headset
Won't show consistent blue light so I can pair with new phone Nokia N95...
Hold down on/off button and volume up button 4 over 5 seconds!!!!!!!!!!! Shazam!
Jun 19, 2008 | Nokia HS-36W Wireless Headset
Please help me with a diagram for hs-23 plug connections...
http://free-zg.htnet.hr/GoranJurkovic/nokia/
http://cellphones.hackaday.com/2005/08/16/how-to-make-a-nokia-pop-port-to-female-mini-jack-with-volume/
Dec 03, 2007 | Nokia HS-23 Headset
Headset not Supported
Nokia HS-3 is a stereo headset.
Your phone does not support stereo.
So Use mono Headsets like HS-5.
Nokia 9300 is a stereo supported phone and hence works with the headset fine.
Dec 01, 2007 | Nokia 7610
No connection withe nokia HS-36W bluetooth headset
First check your headset pair with other handsets if ok. your headset is ok. then check your hand set connection is ok.The default password of hs-36w is 0000
Jan 28, 2007 | Nokia 6230
Search for audio enhancement
Press and hold the On/Off button until the blue light flashes, then search for your headset. This is to initiate the headset for pairing, otherwise it hides from other phones to prevent unintended pairing.
Jan 05, 2007 | Nokia HS-36W Wireless Headset
Cell Phones Logo
293 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
