Question about Vacuums
Correct wiring for CPS VP6D Vacuum pump
I was recently given a CPS VP6D Vacuum Pump that has all wiring disconnected. I have tried contacting Manufacturer and have not been able to obtain a wiring diagram. Any information you have or wiring diagrams would be greatly appreciated.
Best regards
James
5 Suggested Answers
  • 3 Answers
SOURCE: electrolux 2100 canister vacuum
Open the door to remove the bag. Pull the side bumpers forward when the door is open. The profile of the edge of the top and the bottom of the vacum body is a "L" shape. The cross section of the bumper is a "I" and that holds the body together. Carefully lift up the top just a little to free the plastic end cap that conceals the cord spool. There are two plastic pins on the top and bottom that hold this piece on and they frequently get broken. (If that happens repair shops drill and hole and insert a screw.)
There is a plastic protector plate that lifts up on either end and then is slid about 1/8th inch clockwise and then up.
Copy the wiring pattern on the four male connectors on the motor and the wire spool.
Post your wiring diagram and it will solve a lot of people's problem trying to reassemble this machine's -- including mine.
Posted on Jan 07, 2008
LizDahl
  • 75 Answers
SOURCE: electrolux canister vacuum
The easiest solution would be to call your local Aerus/ Electrolux representative, because the corporation doesnt publish diagrams.
Posted on Jan 12, 2008
RockyNR1
  • 324 Answers
SOURCE: Kirby Generation 3 Pictorial or wiring diagram
Go HERE. This should be more than enough info.
Rocky
Posted on May 30, 2009
EwingElect
  • 276 Answers
SOURCE: Where can I obtain a free manual for the
If it's one that look like the one pictured, it's called another name in Australia, but the premise would be the same. Try
http://www.electrolux.com.au/Files/australia_english/Manuals/Cleaning_2007/ZB2812-ZB2813-ZB2815Instructions.pdf
Regards
Posted on May 25, 2010
Will a water pump more water at 65'head than at 85'head. if a 75hp pump will pump 2100gpm at 85'head what will it pump at 65'head thru a 20" pipe
The energy required to lift water is proportional to the head. The approximate answer would be (85/65)X 2100 ~ 2746 gpm. There is a small correction needed for the increased velocity of the water but it is very difficult to determine theoretically. The given answer is probably correct to +/- 5% .
Feb 16, 2015 | Vacuums
My Vacmaster Pro 130 does not vacuum. What is wrong?
Karen, I am the social media coordinator for ARY VacMaster. Most times when this problem arises with a new machine, it's because there are packing spacers on the under side of the lid that weren't removed. Pull those off and try again. If that doesn't work, Give our technical support department a call at (800) 821-7849. You can always "like" us on Facebook (www.Facebook.com/aryvacmaster) and ask questions to us directly there too. Hope this helps. You can contact me there for quicker answers. :-)
Jun 04, 2012 | Vacmaster Pro 130 Vacuum Sealer Food...
I do not get fullstream of water when spray,
Refer to the discussion at the other thread: http://www.fixya.com/support/t3309646-pump_motor_sounds_like_running_but_not
You will need to remove the top domed lid to access the working parts. Refer to http://www.fixya.com/support/t3543424-two_top_sections_held_together
Examine the water lines to ensure they are attached to the pump. If you feel you can do so without shocking yourself on any exposed electrical connectors, try disconnecting the inlet hose. Buy a two-foot section of the same size hose from the hardware store and connect it to the pump inlet. Plug in2_bing.gif the unit (be careful!!!) and use the pump switch to see if it draws water. Then try reconnecting the inlet and connect the outlet to the new hose to see if the pump pulls water from through its suction tube and will pump through the new hose.
If either diagnosis helps, you will know that which hose is blocked and you will need to try to clear it out. Detach the hose which is suspect, so that you have just the hose as best you can. You might try using a wire clothes hangar that you straighten out, or you can have an auto mechanic shoot compressed air into one end. Good luck!
Apr 01, 2010 | Bissell 1672 BIGgreen Wet/Dry Vacuum
The cleaner does not squirt out any cleaner or water. The machine runs but there is no moisture at all being dispenced.
these units have alot of pump failure problems. most likely the pump has gone bad. check the pump motor with a continuity tester if the pump motor is good disconnect the exit hose from the pump and see if it pumps any water
Feb 26, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Pump motor sounds like it is running but is not pumping
The pumps in these machines are very simple and there's almost nothing to go wrong. If the problem is actually in the pump, the most likely thing is that there's something stuck in one of the valves, but this is unlikely as long as you've got an undamaged filter on the intake tube in the clean water tank. More likely is that the diode has failed in the live wire supplying the pump. The function of the diode is to act as an electrical one-way valve, and if it fails the pump will sound like it's working but it won't shift any water. I don't know of an easy way to check the diode, but replacing the pump lead-wires should be cheap. If that doesn't solve the problem, fit a new pump (they're not expensive).
Good luck! Please remember to rate this response, thanks.
Oct 29, 2009 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Pump runs but won't pick up solution from tank
I have the same problem. Pump runs a little sluggish but water does go up the siphon tube.
CR
Jul 15, 2009 | Bissell 1672 BIGgreen Wet/Dry Vacuum
My pump runs but won't pump
Examine the water lines to ensure they are attached to the pump. If you feel you can do so without shocking yourself on any exposed electrical connectors, try disconnecting the inlet hose. Buy a two-foot section of the same size hose from the hardware store and connect it to the pump inlet. Plug in the unit (be careful!!!) and use the pump switch to see if it draws water. Then try reconnecting the inlet and connect the outlet to the new hose to see if the pump pulls water from through its suction tube and will pump through the new hose.
Nov 16, 2008 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Pro heat pump
That is correct; the new pump has a metal pulley, which is more durable.
J
Jun 07, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Vacuums Logo
208 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
