Question about Saeco Vienna De Luxe Espresso Machine
Saeco Vienna de luxe no coffee comes out
Hello machine grinds, even end up in the box for the trash grinds but no coffee comes out
    President:
  • 1,618 Answers
The brew unit is blocked, remove unit and then remove the screen located at the top, clean screen and reassemble.
Posted on Jul 10, 2009
Saeco Vienna. Wet cofffee grinds in the dump box.
It could be the grind on the coffee or the red group o-ring and the 2 o-rings on the white plastic valve need to be replaced.
Nov 05, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna grinds too much coffee.
Hi
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
Jul 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Change the grind in Saeco Vienna Deluxe coffee maker
Hello kgspco.
You will need to work the 'dial knob' untill it free's it-self.
The higher the number the Coarse(r) the grind.
If you want rich - dark - strong coffee, set number between 4 - 8.
(if you can free it up - keep trying
Jul 06, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe grinds but plugs up at door
Try this: clean out the chamber, then set the grinds coarser to see if it makes a difference. If it does not then the micro switch or solenoid that controls the door is broken. Check resistance on solenoid it may need to be replaced.
May 10, 2009 | Saeco Vienna De Luxe Espresso Machine
Red warning light comes on and stops
put a cup under the water spigot and turn the knob to release the pressure
Dec 09, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso is leaking water
It can be the steam valve or the boiler that is leaking.
Aug 05, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco De Luxe Coarse Grind
You could have knocked it out of its shaft or worse, Cracked the shaft itself.
Settings could be off too, It fairly common. Recheck the chamber, and make sure the plastic casing isn't cracked and the grinder doesn't wabble at all. It should be fairly firm.
If it isn't firm, bad news, cracked shaft.
May 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Coarse Grind
il y a de l'eau qui passe en dessous du plateau avec du café moulu
Saeco Vienna De Luxe Espresso Machine Logo
256 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
