Question about Refrigerators
Ice maker donot make ice - Refrigerators
  • 66 Answers
Turn off the ice maker for a few hours by flipping the metal lever and wait about 2 house then try it again could be that it is humid out and the ice maker doesn't like it
Posted on Jul 03, 2009
  • 72 Answers
What brand and how old
Is it OK for ice thickener sensor touch water on ice maker
Yes, it has to touch the water. As the ice builds up the thickness sensor moves up and turns of the refrigeration and turns the heater on.
  • How Icemakers Work ' HowStuffWorks home.howstuffworks.com/icemaker.htm How Icemakers Work. ... we'll look at the cycle an icemaker goes through to make ice. ... Get the best of HowStuffWorks by email. Keep up to date on:
  • How Does The Ice Maker On A Refrigerator Work ... - YouTube www.youtube.com/watch?v=x4YDWUK0jv8
    • BY REPAIRCLINIC.COM
    • 4 MIN
    • 347K VIEWS
    2012-05-15 · Video embedded · This video provides information on how a refrigerator icemaker works and offers troubleshooting tips ... How Does a Refrigerator Water and Ice Dispenser Work?
  • How Ice makers Work - ApplianceAssistant.com applianceassistant.com/.../Ice-Makers/How-Ice-Makers-Work.php How Ice Makers Work! Learn How Ice Makers Work, ... How Ice makers Work. The Ice Maker Cycle ' Ice Maker Components ' Cube Size Replacement Ice Makers . They Don't Make
  • How Does an Ice Maker Work? - Reviewed.com Refrigerators refrigerators.reviewed.com/features/how-does-an-ice-maker-work Here's how your ice maker works. BACK TO . Best Right Now; How To s; Award Winners; How We Test; ... How Does an Ice Maker Work? It's more complicated than ...
  • Refrigerator Icemaker Repair How It Works
    May 12, 2016 | Refrigerators
    I have a Performa refrigerator by Maytag with Ice maker bought in 2000 -Model # PTB 1953 DRW. The Ice maker had frozen at spout that fills the tray in the freezer. I finally cleared the ice plug with an...
    HI,
    The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
    Aug 25, 2008 | Maytag Refrigerators
    Icemaker
    Here is a solution I found on a different site:
    Try this..using some hot water and a squirt bottle with a tube about a foot to a foot and half long (about 1/8 to 1/4 inch diameter) to melt the ice (if present) and return it to working order most of the time. There is a black tube to the right of the ice maker on the roof of the freezer, if you squirt the hot water there, it should fix it, if there was an ice blockage..This way you donot have to defrost the fridge :) Here is a pic:
    It would be better if you take off the ice maker and the ice maker cover. The ice maker cover comes off by lifting it up and pushing it to the right, the pegs come out of the holes then. The ice maker is removed by one bolt at the bottom of the ice maker. Here's a pic to help you locate it:
    Once the ice maker is moved out of the way, you can easily feed the tube into the black hose and turn the bottle upside down to push the warm water into the hose. It should then melt any ice and it should all come draining out. Keep a dish underneath the hose to catch the water and (hopefully) the ice that was blocking the hose.
    Re-assemble and wait a few hours to see if your making ice again.
    Also note if you see a flashing red light just inside the freezer door where the button is to turn on and off the ice maker. A flashing light means problems with the sensing PCB. Look behind the kick panel under the refrigerator door for the service info sheet. It will give diagnostic info for these boards.
    Also, a solid red light means that the door is open and the ice maker will not make ice. If you hit the big white switch to the left of the door (hinges area), the light switches to solid red. This tells the ice maker to start making ice. The little holes under the red light are sensors that tell the ice maker when it's full. Make sure that these are not blocked in any way, and are clear, or it will give wrong info to the control panel saying that the ice maker is full..
    Hope that helps!
    Jun 10, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    Water chute in ice maker keeps freezing?
    note that doors of frige should be tightly closed, fan in freezer side should be on & running condition, donot put the items in freezer closely,there should be more gap within all items,adjust thermostat to lower position about half,then press autodefrost switch ,wait for auto restart about one to three hours
    Dec 12, 2014 | Amana Refrigerators
    Ice maker
    Before going to buy any parts directly.
    Go through this troubleshooting help links.
    This is list of refrigerator problems, which is normally faced in refrigerator.
    You can go through the details, by clicking the link below:---
    Refrigerator is not cooling properly?
    http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
    Both refrigerator and freezer not cooling properly in refrigerator?
    http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
    The ice maker not working: ---
    http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
    Compressor not running on refrigerator?
    http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
    Water dispenser not working on refrigerator?
    http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
    Ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
    Water Overflows in Ice maker and freezes inside?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
    How to replace Ice maker assembly?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
    other ice maker related issues and solutions:---
    Ice maker dispensing ice with black or white plastic pieces in ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
    After replacing ice maker assembly, ice is not getting made?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
    Ice maker is leaking water and causing the ice to freeze?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
    Ice maker is noisy and not making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
    Refrigerator ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
    Ice maker leaks water into ice bin causing a glob of ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
    Amana Refrigerator leaking water from ice maker?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
    Ice maker leaking?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
    Ice maker is dumping the ice cubes out before frozen solid.
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
    Water overflowing ice maker?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
    Ice cube is getting stuck up hard in ice maker
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
    Icemaker quit working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
    Quit making ice
    http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
    Water leaking into ice tray, frozen glob of ice
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
    Not making ice, and water leaking in freezer?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
    The ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
    Ice maker not making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
    Ice maker quit working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
    Ice maker dispensing black pieces of plastic in the ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
    Replaced Ice maker but its still not making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
    Ice maker leaked creating an ice block?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
    Ice tray leaked?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
    Ice maker stopped functioning?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
    Ice maker stop working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
    Ice maker failed
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
    Old ice maker stopped working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
    Old ice maker started leaking?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
    Ice maker not working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
    Ice maker overfills and cause water to flow into ice dispenser and freezes?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
    Ice maker didn't make ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
    Ice maker was leaking?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
    Ice maker was leaking after it filled up with water?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
    These will help.
    Thanks,.
    Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
    GE Ice Maker freezing
    Not sure exactly what you mean by the ice maker freezing, ice makers are suppose to freeze. But if you are referring to the ice maker not being able to harvest the ice since it is frozen in there to tight, then the heater that is on the bottom of the ice maker has failed and you will need to replace the ice maker.
    Here is a link to the new ice maker.
    Oct 15, 2012 | Refrigerators
    Do i need to change the filter in order to get the ice maker to work? the water still come out but not into the ice maker. please help!
    no you donot need to change the filter first. all of the water goes through the filter first. you either have a bad water valve for the ice maker. a bad ice maker. or bad optics that sense the ice bin on the door is full. can you move the ejector blades on the ice maker? that will tell you if the ice maker gear is broken.
    Apr 25, 2010 | Whirlpool GS6NBEXR Side by Side...
    Icemaker not making ice
    Sounds like you need to replace the ice maker. The mold heater appears to be defective.The mold heats up prior to a ice dump. I donot believe it is worth repairing
    Sep 29, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
    yes, there is 2 lines, one for the water and the other for the ice. you can take the back lower panel behind the frige and take a look at the water line coming from the house where it connects to the frige, you can disconet the line that goes to the freezer, and put the line inside of a container of about 1 litter, and waite for about 30 minutes it at to have some water inside just enough to fill the ice maker. if you donot get any water, replace that valve.
    Dec 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    Refrigerators Logo
    123 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
