Question about Boating
Hi. Just a quick one: I just bought a 1996 Johnson J35QLED. Do I have to mix oil & gas?
  • 23 Answers
Is there a place under the cowling to put outboard motor oil if not mix 50 to 1 to be safe if will not hurt the motor to add oil to the gas,but if you dont you will burn up the motor. Jim OMC REtired Mech
Posted on Jul 07, 2009
Gas oil mix for 1990 evinrude 6hp
Mix 8 ounces of two cycle oil to one gallon of gas.
Jun 09, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Do you mix the gas or just straight gas, where do you check oil
that old oil is to be mixed into the fuel 1 pint per 6 gallons of gas . only other oil is the gearcase lube
May 15, 2016 | Boating
Does 1984 25hp johnson at tor need 2cy oil mixed wiyht gas
All 2stroke engines need 2stroke oil in the fuel !!! 50 to 1 mixture ! fuel to oil !...
Sep 23, 2014 | Seloc Johnson Outboards 2002-2007 Repair...
I have a 1988 hurricane deck boat with a johnson 110 vro does it have a separate oil tank or do I mix the gas and oil in the gas tank?
seperate tanks VRO stands for variable ratio oiler .unless it has been disabled gas and oil don'y need mixed
Jun 23, 2014 | Boating
Have just bought a 1993 90hp v4 johnson and would like to know what type of oil to use in the oil resevior
Any tcw3 two stroke oil . I am a marine mechanic and I would recommend disconnecting the vro which is the oil injection. Just disconnect the oil line and then mix the oil in the gas 50 to 1. The vro is known for going out and taking your motor with it
Dec 03, 2012 | Boating
What type and weight of oil for johnson 28 horse outboard boat moter
Hi, mix the gas and oil at 50 to 1 and use two cycle outboard oil. Regards Phil.
Jun 29, 2012 | Seloc Johnson Outboards 2002-2007 Repair...
Just bought a garman 14 ft. jon boat wide version.has 14hp johnson outboard 2 cycle motor 2 clycle.(manual) start.i have replaced spark plugs.i took it out twice now .First time out it started right...
Check fuel filter first to see if there is any trash or water clogging it up. Make sure the gas tank is venting and the fuel connections are secure. Check both cylinders for spark, the gap should be around .030". If motor cranks up and tries to die again pump the primer bubble to see if this helps, if it helps this would indicate a fuel pump problem, if not then the first thing I would do is clean the carburater which is more than likely what is wrong.
Aug 08, 2010 | Johnson Ma100 Lynchburg Mandolin
1985 40 hp Johnson outboard wouldnt open up and
sounds like your mix is off and it's fowling the plugs. probably too rich. make sure the level in your carb bowls isn't too high. Really sounds like you should clean and bench set your carbs. Especially if a plug change helps but doesn't last, then it's got to be your fuel mix, or maybe timing.
Jul 16, 2009 | Sport & Outdoor - Others
Oil & Gasoline
Hi Thomas, you can find bar oil for the chain at just about any hardware store. Just tell them you need chainsaw bar oil. The oil that mixes with the gasoline is called 2- cycle mix. They will have that also. You can find the 2- cycle mix at a lot of gas stations too but a lot of guys caution not to use the 2 - cycle mix that is made for outboard motors. . Hope that answered your questions.
Jul 11, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Are the 1988 Johnson vro oil injection system dependable?
the older ones are dependable but they all exspecly being that old its better to be safe than sorry its if it were mine i would mix the gas thats what i tell all my coust the 90 thr 1999 omc vro were terrible the fill the carbs full of oil so i would just mix it that way u know its right just use good oil and that engine will last a very long time good luck
Jul 07, 2009 | Boating
Boating Logo
98 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
