It runs on battery, has propane, has fridge, sleeps 10, has awning and I need to know how to work water, electrical, empty waste, and find repair parts for the awning has been torn down by water weight.
SOURCE: Morphy Richards Astral RV fridge
The Guest Post of May '09 is very accurate. I have a problem with the glow igniter associated with the black button. I need a new igniter and wonder if anyone knows where I can get parts. My model is a 7307 Morphy Richards Astral Frig.
Mel Mashman
[email protected]
SOURCE: dometic rm2852 does not run on gas
So, the solution was simple but not obvious: the heat probe and the igniter are one and the same item, and all we had to do was bend the probe/igniter closer to the burner. After we did that the refrigerator started to behave properly.
Oddly enough, the repair manual for the refrigerator shows a igniter with a heat probe above it: the is not how the refrigerator is built.
SOURCE: camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
SOURCE: i have a dometic rv fridge. it works on the 120
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
SOURCE: 98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
