My paper size is 8 1/2 x 14
The printer takes A4, Legal and letter size paper.
see the specifications at this site.
Lexmark Prospect Pro205
SOURCE: Want to print on legal size paper from Tray 1 (top) as default
print menu - config and verify paper is being sensed correctly. If paper size in tray is not set correctly printer will ask where to print from
SOURCE: Lexmark Prospect Pro 205 printhead error
where can order a new printhead for my lexmarkpro205?
SOURCE: Paper will not feed into
hi,
Lets clean it this way;
- open any documents
- go to file > print ( or ctrl + P)
- When the print window opens click 'properties'
- In the properties window click 'Maintenance'
- 1st do the normal 'cleaning'
- 2nd do the 'deep cleaning'
- do the print Head Alignment'
- do Nozzle check'
- Skip 'Ink cartridge settings' (if the ink level is ok)
- do 'Bottom plate cleaning'
- do 'Roller cleaning'
- click 'OK'
- turn Off and ON printer.
Now insert the load paper and take print. : ) done
Hope this helps.
Please rate if this solution was helpful, thanks!
Updating the firmware of your printer will help with the issues that you're experiencing. Just go to http://bit.ly/ghfW8H to download the firmware update. After the update, try to perform the Deep Clean Printhead again.
Your printer and the devices trying to print from it should be connected to the same network. If it is, download our LexPrint app to your iPad http://bit.ly/IMbDlq. Since the Lexmark Pro205 is not AirPrint compatible, you would need the LexPrint Listener installed to a host computer.
Our latest Inkjet printers are already compatible with AirPrint.
