Question about Samsung Televison & Video
MY SAMSUNG DIGITAL TV HAS JUST HAD NEW PSU FITTED COULD THIS HAVE AFFECTED THE QUALITY OF PICTURE
  • 304 Answers
I take it you mean a new Power Supply. The answer is no. There is probably another issue here. If you replaced the power supply your self then you did something to affect the pix quality. If a Tech replaced the power supply he should have tested the tv using the source you use to watch tv and make sure the pix quality was as before the repair was done. Hook up a DVD player to the same input and see what you get. The old power supply might have damaged the Main bd as well or your source might have gone bad or has a weak signal. You have some work to do.
Posted on Jul 17, 2009
How can I assure that the power supply unit PSU is defective?
You only need a PSU board if the back light inverters are combined with it. Otherwise look for the inverter board. To be sure it's defective, when the picture goes off shine a flashlight on the screen to see if you can spot movement from the program on the screen. If you can see movement then the inverter board needs replacing. If you can't see any movement then the T-Con board is bad. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 02, 2016 | Element Electronics FLX3711B 37 in. LCD TV
I have a Samsung 46" TV (LCD) which will not display a picture. The white light in the bottom center area lights up and the Red Light in the bottom right hand corner continues to blink. Finally, about...
had a totally knackered Samsung power supply which had to be replaced when I fitted new psu had clicking coming from new psu which turned out to be a faulty relay on the new Samsung p.s.u replacing the relay on the new power supply board got the TV working 100%
Mar 26, 2015 | Samsung Televison & Video
Hi, I have a Samsung HR720 DVD-TV recorder and since we have gone digital the quality of the picture recorded is blurry. I have checked the back of the recorder and it doesn't appear to be any option...
Hi, Check the settings in the TV menu. Set the sharpness abit higher. Also if you have already you need a set top box (PVR) to view digital signal and to record it as well. Good luck.
Jul 21, 2011 | Samsung DVD-HR720 DVD Recorder
Samsung 40" tv sound is
The box might be defective as the company to exchange it. You can try swaping the box to the other TV and see if it happens on the other TV.
Jun 03, 2011 | Samsung Televison & Video
Following the beginning of digital switchover, pressing the menu button only comes up with 'picture quality' and is unable to access 'installation'.
If your TV is not in Digital it won't give you the tuning option.
Select DTV from the on screen menu, (like scart 1 scart 2 etc). When you have found DTV select it and then press menu for tuning.
Hope that helps.
Mar 30, 2011 | Televison & Video
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
46" screen with an <8 x 11 picture!
you should contact samsung and inquire as to poss.warranty defects of this item
Aug 23, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Best Picture Quality
The set may not be at fault. If you are on cable some channels are still in anolog and some are digital. if you are on a nolog channel the picture will look preaty bad compared to the digital ones.
May 09, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Picture quality
i have a similar problem, when watching football the picture is terrible,but when im watchin ordinary tv its great
Dec 28, 2007 | Samsung LN-R409D 40 in. LCD Television
Televison & Video Logo
70 people viewed this question
Jerry Greenberg
Jerry Greenberg
