Question about Lexmark C510 Laser Printer
910 service engine + 900 service RIP software
Our Lexmark c510 printer had a 910 service engine motor error, i saw online that removing and replacing the photodeveloper cartridge might help. I did this and now i have a 900 service RIP software error. The printer then makes a grinding like noise when i press go. How do i fix it?
931 service
Posted on Jul 09, 2009
I got message (900.00 service rip software) on my lexmark T644 printer. What does this mean
900 rip is a inrecoverable software error POR printer take data cable out and POR should clear if not then system bord needs replacing more likley corupt dat sent to printer
Sep 16, 2011 | Lexmark T644 Laser Printer
900 service rip software error on our Lexmark Optra S1855 what does it mean? How do I fix it?
These errors indicate an unrecoverable engine software
error. Replace the engine board is the only solution
Apr 07, 2010 | Lexmark Optra S 1855 Laser Printer
Printer lexmark C510," 956 service TCSD system board"
With that " 956 service TCSD system board" error message, the only you can do is to replace the Rip/System Board. Hope I can assist you more on this.
Apr 06, 2010 | Lexmark C510 Laser Printer
Lexmark C510 not printing - message 900 service RIP software
Hi, This error could be due to several things, the most common one is that whatever is being sent from the computer is not being recognized by the printer causing the 900 Rip Soft Error. You can try to reset the printer and try sending the print job again. If the error persisted. Then the problem could be a hardware problem with the System Board.
Jan 13, 2010 | Lexmark C510 Laser Printer
I have a Lexmark C510 which display a 910 service engine motor. Can you tell me what motor this is?
910—Developer motor service check
Step Questions / actions Yes No
1 Are there any unusual
noises heard around
developer motor or
developer drive assembly
before error posts?
Replace toner
cartridge
Does problem go away? Problem solved.
If not Replace
developer motor
and/or developer
drive assembly.
Partnr developer motor:
56P1627
Partnr Drive assy: 56P1628
Jul 15, 2009 | Lexmark C510 Laser Printer
900 Service RIP Software
Are there any memory or Barcode SIMM's in the printer? If so, remove them (power off first!) and turn the printer back on and see if it acts normally. I have had 1 instance where the Barcode SIMM has caused that error. The Barcode SIMM had to be replaced. Most other times the 900 RIP error occured, a simple turn off/on "fixed" it (sometimes only temporarily). If all that doesn't help, flash the engine code with the latest from Lexmark support. If that doesn't do it, then engine and/or controller card need replacing.
Jul 07, 2009 | Lexmark T520 Laser Printer
900 service RIP software error on boot-up
removed memory off the system board restarted printer. came up to an error no memory found.
powered down and reinstalled memory on board in a different slot and restarted unit...
NO ERRORS......
May 24, 2009 | Lexmark C750n Laser Printer
900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
May 04, 2009 | Dell Office Equipment & Supplies
Lexmark x422
900 RIP errors are errors in the Engine Code. There is an EC1 file available at: http://support.lexmark.com/perl/support/support.cgi.
Download and install the file by following the link on the above page, first error discription.
Don
Mar 08, 2009 | Lexmark X422 All-In-One Laser Printer
My printer won't print
Throw out your POS lexmark and buy something else
Jul 01, 2008 | Lexmark C510 Laser Printer
Lexmark C510 Laser Printer Logo
1,742 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
