Question about Alpine CDA9812RB CD Player
How to switch aux on!
Hi i just purchased an ai net cable for aux with a red and white aux cable to connect my ipod or mp3. for some reason i read the manual and it said to switch the aux on but when i try this it doesnt work. Can anyone help.
Thanks
Baldingwhirl
  • baldingwhirl Jul 03, 2009
    Hi e-Guru
    I have attempted this after your advice and for some reason the radio switches back on when i push and hold the multi function knob. I also tried to just tap the knob and the unit turns back on.
    Im sure im doing this right but its not working.
    Baldingwhirl
    Hi e-Guru
    Sorry i managed to find out how to turn this on. There is a setup button and i push/hold it for 3 sec or more and it came up with a menu. I then used the << >> keys to search through the menu. Once i found the aux off then switched it on using the BAND/TEL button.
    Finially i can enjoy more music through my ipod.
    Thanks for your help
    Much appreciated.
    baldingwhirl
  • 10,594 Answers
Good to know that problem is solved.
Thanks.
Posted on Jul 03, 2009
    Brigadier General:
  • 3,917 Answers
According to the manual, you need to "enable" the AUX 1 or 2 thru the initial settings menu.
Press and hold the SRC until the unit turns off. Then press and hold the MULTI CONTROL (knob) until the Language appears. Turn the knob to cycle thru the options, select AUX 1 or 2 and press the knob again to select ON.
After selecting them to on, power the unit on and press the SRC to cycle thru the sources to find AUX 1 or 2.
Please checkout the bellow link which gives a detailed aux setup for an ipod.
http://www.crutchfield.com/S-fXZ8CjrHbwN/Learn/learningcenter/car/ipod/ipod_installation.html?page=4
Thanks for contacting Fixya.
Alpine 7889 interface not working correctly
hook all of the wires up, then hook the red blue and yellow wires all together.
Jan 28, 2014 | Alpine Kca-420i Kca-121b Ai-net3.5mm Mp3...
Ai-NET cable is cut, wire splice male aux cord
On the ai net cable identify and separate strand with green, blue and unshielded common/ground. G and B will be your positive which you will then solder to red and white leads from rca or headphone cable with unshielded from that cable twisted together and soldered together with the unshielded wire from ai net cable. Tape off or heat shrink the rest of wires from ai net cable.
Sep 29, 2013 | Alpine CDA-7863 CD Player
How do I hook up my ipod to my pioneer vsx d409 ?
The best way is to use a 3,5mm stereo jack to 2 RCA cable like this:
You can easily find one like this at your local audio/electronics shop or buy one on line. You have to connect the RCA at any free stereo input at the back of your Pioneer (like aux or cd). Take a look at this picture:
After this you can use the 3.5mm stereo jack for connecting not only your ipod but every mp3 player or other device has an earphone jack. Just plug the 3.5mm jack at the earphone jack and rise the volume at the portable device up to the middle of the volume range and set your Pioneer input selector at the stereo input that you connect the 2 RCA before (aux or cd)
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 13, 2011 | Pioneer VSX-D409
Want to connect ipod, how can i do that
Its on the back of the radio. Here is the link for the part you need to convert to rca's so you can plug in a ipod.
http://cgi.ebay.com/Alpine-Ai-Net-RCA-Aux-Input-Cable-KCA-121B-for-IPOD-A1_W0QQitemZ110466314443QQcmdZViewItemQQptZOther_MP3_Player_Accessories?hash=item19b84e30cb
Apr 08, 2010 | Alpine CDA-7897 CD Player
Auxiliary Audio Cable
It is the AI net plug on the back of the radio, radio must be uninstalled. Just mathch up and go!
Hope this helps
May 30, 2009 | Alpine CDA-7892 CD Player
On my Alpine CDA 7892 i have the aux cables right for my iPod but i don't know how to swith it to the "aux" , just CD or Radio, How do you switch it to the "aux" imput in the back
I believe you need the Alpine KCA-410C - Ai-Net multi-changer/versatile link adapter before you can input from an external source directly.
Mar 28, 2009 | Alpine CDA-7892 CD Player
MP3, IPOD, CD doesn't appear when I press "Source"
Easy.
If you read your owner's maunal, page 26, the USB is designed for a flash drive (up to 4GB), not an Ipod.
If you would like to play your iPOD, purchase the IPC008 (Ipod Lead) and you're done!
Feb 24, 2009 | Eclipse CD1200 Car CD/ MP3 Player
Can i connect my alpine tda7592r headunit to an to an ipod thou the aux
CLICK HERE for your owner's manual.
Yes, you can purchase the following Ai Net cable that works through the changer port on the radio...
It is available HERE.
Or available at your local installation shop.
Thanks for using Fixya - A FiXyA rating is appreciated!!
Jan 23, 2009 | Car Audio & Video
Connecting a Zune MP3 to the HT-X50
Get an Aux cable(about $10) and connect it to your Zune player and to Aux 1 on your Sound system. Make sure you change your function to Aux 1. Do not connect USB or anything else. That's working for me.
Jan 21, 2009 | Samsung HT-X50 System
What is the AUX good for
I use the Aux to plugin my Ipod, amke sure you have it set on. Then it acts as the plugin. it was originally there for XM radio or a tv.
Sep 24, 2008 | Alpine CDA-9805 CD Player
Alpine CDA9812RB CD Player Logo
361 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
