Serial number is 4553613. this tv is mounted on the wall. Thanks in advance for your help.
It's caused by the Bravia Sync feature. It doesn't always connect correctly. When there are issues then attempts to sync up cause the menu to appear.
The solution is to switch off Bravia Sync.
Go in to the TV's set-up menu, and choose HDMI Set-up.
Scroll down the menu list and choose Control for HDMI, then set the menu option to OFF
Let us know if that fixes the problem for you.
SOURCE: Sony Bravia KDL-S40A12U Blank screen
Hello
on your set there is inverter board that is what lights up th backlight on your TV making everything visible that board has went bad.
Thankyou
SOURCE: KDL-46V2500 Please show back panel. which screws are mounting screws
yes, i removed mine. no problem.
SOURCE: flashing red standby light
Take it down from its mount and try to restart it if this resolves the issue your mount is too tight on the back of the lcd monitor.. This happend to me as well good luck with your BRAVIA
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: how do I remove the stand of the Sony Bravia XBR
you have to lay the tv on it's front on something to protect it from being damaged.on the back you'll see where the base joins the bottom of the display, this needs to be unscrewed and a wall bracket screwed in instead.
SOURCE: have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
