Question about Thomson Washing Machines
Washing machine Thomson WDT-1000 I needed Thermo reguleitor or analog. Please HELP!!! Drying does not work.
  • 74 Answers
SOURCE: Creda 1000 simplicity washing machine
try
www.theservicecentre.co.uk
creda and hotpoint website
good luck and rate me
Posted on Feb 17, 2008
SOURCE: how to use thomson washing machine tx 708
solved.
Posted on Jan 28, 2010
SOURCE: Bosch Classixx 1000 Express washing machine won't fill with water
my washing machine bosch clasixx all in one does not rinse clothe properly. there is a residue of washing powder. Where is an extra rinse button
Posted on Jun 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: have hotpoint ultima 1000 wm17 washing machine run
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
SOURCE: My Thomson TX898 washing machine,
I have the same problem 2, DO2 on Thomson TX898
Posted on May 28, 2011
Wf-t8019ql. I'm confused how to solve this problem d3 error
try unplugging this device for 30 seconds then plug it back in to see if its a security code if this does not help call your local lowes or professional repair shop about the code I am not familiar with the brand new digital washing and drying machines only the old timers with analog's merry christmas
Dec 26, 2014 | Washing Machines
Zanussi turbodry wdt 1075 washing machine fills & drains but does not perform wash cycles or spin cycles drum does not rotate
Quite probably the motor brushes. Disconnect from mains. Tilt machine backwards as far as possible. On motor, disconnect wires to brushes. With a multimeter, check continuity between brush and any segment if the commutator. If open circuit, replacing the brushes should do the trick. Also visually examine the commutator for damage
Aug 17, 2014 | Zanussi Washing Machines
My zanussi WDT1072 does not spin the clothes dry any more. What could be the causes?
Check the drive for friction, it must move freely with your hand movement. If not it is possible that the bearing or accumulation of dirt has caused this to happen which can result in LOW RPM and thus the speed is less for drying .
Click On : Bearings
Jan 23, 2013 | Zanussi Washing Machines
How to use thomson washing machine tx 708
I misplaced the manual of my Thomson TX829, please can you advise where I can obtain a new copy.
Jan 15, 2010 | Thomson Washing Machines
Machine keeps stopping and showing fo5
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Oct 22, 2009 | Washing Machines
Error E20 showing ........stops during wash cycle and clothes not dry on drying cycle
not familar with the code but usually wash has a built in thermo stop to wait for water to heat to correct temp,if it works normally in a rince cycle and spins out and finishes properly i would look at heat element or stat,hope this helps
Apr 06, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
My Thomson S46-55 washing machine spins BUT does
Check to see what is the story with motor and belt tht turn drum and extract water. If belt has stretched it needs to be replaced. Search Over 2 1 Million Appliance Parts
Sep 11, 2017 | Thomson Washing Machines
Need a manual for whirlpool washer/dryer awz410 1000
Make sure the half load / drying button is pushed in also and the drying time set.
Do you know whether the temperature dial controls the washing or drying cycle. Have shrunk too many jumpers. Thanx
Feb 20, 2009 | Whirlpool AWZ410 Front Load Washer/Dryer
Washing Machines Logo
66 people viewed this question
Top Thomson Washing Machines Experts
Garth Jackson
highlander28
Level 1 Expert
Are you a Thomson Washing Machine Expert? Answer questions, earn points and help others
