Question about Porter Cable Cable 14.4 Volt Cordless Drill/Driver Kit 9824
Seems like the clutch has gone in the drill. Can this be replaced? When I squeeze the trigger the motor turn and the drill spins but if I put any pressure on the chuck it stops spinning even though the motor is still turning.
  • 32 Answers
Try rotating the driver adjustment to make sure it is on a definate number, not in between or put it all the way to the drill position. A little 3-in-one oil does wonders as dirt and dust will keep it from rotating and engaging easly. If this does not work and the clutch is stripped, cost of rebuilding it is not worth it, usually 70% to 80% of a new one and other parts on it will wear out and you will be fixing it again. Good Luck
Posted on Jul 14, 2009
Core drill model number is cb748. Will not spin, how do I troubkeshoot the problem
Very likely the clutch has engaged. You should only need to slowly turn the spindle by hand while using the speed selector switch to put it back in gear. If there is something else going on, you may want to look at the parts list which you can find here:
http://www.buildersdepot.com/core-drilling/core-drill-motors/core-bore-cb748-110v-20a-core-drill-motor.html
and most common replacement parts:
http://www.buildersdepot.com/core-drilling/core-drilling-accessories/cb748-replacement-parts.html
May 16, 2014 | Drills
I have the drill, I have the bits...there is something missing to connect both. What does it look like?
Although you posted your question under Chainsaws instead of another tool forum, look at the end of the drill. Is there a hole surrounded by a cone shaped metal end? This is the chock, if you spin/turn it counterclockwise, the opening should widen to accommodate the drill bits, then spin/turn it clockwise to tighten/clamp down on the drill bit. Some drills accomplish this with an l-shaped key that has a small cone-shaped gear on the end that fits into holes on the chock. Some drills have a chockless drill, and you simply hold the end of the drill and squeeze the trigger to use power to tighten/loosen the bit.
Aug 31, 2011 | Garden
How do I change the drill bits and then tighten so the bits stay in the drill?
The chuck will not turn. So to loosen just turn the black plastic counter clockwise. The chuck will loosen. Or you can hold the black part on the chuck tight and put the drill in reverse and slowly squeeze the trigger and the chuck will loosen also. Do the opposite to put a new bit in. Put the drill in forward and hold the black part of the chuck and squeeze the trigger with the bit in place and it will tighten down on the bit.
Dec 16, 2010 | Dewalt 18 Volt Compact Drill Kit
Clutch problem on drill??
or it could be as simple as it became loose, open the chuck all the way , look into the hole in the middle,, you'll see a screw head,, tighten it
Aug 03, 2010 | Milwaukee Tool Milwaukee General Purpose...
How do I change the bit in the Makita 6222D 9.6V cordless drill?
put the drill in reverse hold the chuck housing ( the black plastic piece around the bit) and squeeze the trigger. Hold it tight and it will pop loose, pull out the bit reinsert new one. Put the drill in forward squeeze the housing tigh and pull the trigger it will tighten right up.
Feb 26, 2010 | Saws
How do I attach the drill bit to the chuck on a ss 120 drill
Well I couldn't find a pix of your drill so I will guess that it is a typical drill. You seem to be asking a very basic question so I will start will all the basic info I can think of.
First you have to know where the power trigger is to make it go.
2nd you have to know where the forward and reverse switch is.
Now with the switch in the forward position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the center Jaws should close up and come out of the chuck.
Now with the switch in the reverse position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the cetner Jaws should open up and go into the chuck to a maximum point
Open the jaws enough to put the drill in the jaws then put the switch in the forward position. Put the drill in the chuck, sqeeze the trigger to make it go, and hold the chuck so the jaws close on the drill. All while keeping the drill from falling out of the chuck.
When it closes on the drill and the drill is in straight then hold the chuck as tight as you can while squeezing the trigger to make the jaws close very tightly on the drill. If you have very tender hands you might want to use gloves.
To get the drill out put the switch in reverse, hold the chuck very tightly, and squeeze the trigger to open the jaws off of the drill.
Nov 28, 2009 | Black & Decker Drills
We were using a makita cordless power drill. Somehow the clutch got stuck and it won't spin or open where you put the drill bit in. The motor seems to be spinning, think the problem is just in the...
keyless chuck. grab the ring immediately behind the chuck and the tampered chuck piece with a padded channel lock plier. turn the chuck part clockwise to release.
Oct 26, 2009 | Makita Drills
Keyless chuck is locked; won't turn
you will need to replace the chuck.look inside the chuck for a screw. it will be a left handed screw.once you get the screw out put the chuck in a vice . you will need to squeeze it very tight. then put the drill in reverse and pull the trigger.if i wont come off you will need to hit the chuck with a hammer while you are holding the trigger.
Oct 01, 2009 | Drills
Drill was working intermittently but now it ceased
With the DeWalt cordless drills, the weak link is that the leads tend to burn (melt) off at the motor brushes, It's happened to mine now about 3-4 times, so much so I've had to replace the wires after they got too short to put a new terminal back on them!
The only other issue is that the trigger mechanism could be faulty. but before you spend the bucks on that, you can easily check to see if it't the wiring or the trigger assembly.
Before you take anything apart, make sure the top speed selector is at #1, and the torque setting set to the lowest setting. (makes it easier to remember if you have the speed selector come out of the drill body)
Now lay the drill on it's side and with the battery out of the tool, remove all the screws that hold the two halves together. Take off the top half and look at the back end of the tool to see if the wires going to the motor are in good condition and not burned off the motor brush tabs. If they are, you can either resolder them or recrimp them (DeWalt used different methods for different models) with a new .25 female terminal (any auto or hardware store will have them)
You can give the repair a quick check (IF you are careful) by putting in the battery into the lower drill body and holding the drill motor, gently squeeze the trigger and see if the tool runs. If so, you've fixe it and can put the drill back together.
If the wires are good, then it's the trigger assembly and you'll have to get one from either a DeWalt Authorized service center or distributor that carries repair parts, as these are sealed units and can't be fixed (I've tried). There are some available online too, if you wish to do the replacement yourself, which is a straight forward unplug and plug operation, now that the tool is apart.
Reassemble, making sure the speed selector is in the slots on the tool body and everything else lines up correctly. Install the screws and you're back in business.
Hope you find this very helpful and best regards!
Aug 23, 2009 | Dewalt 18 Volt Compact Drill Kit
How to unlock the chuck
this how to get a chuck off a drill.look inside the chuck for a screw. it will be a left handed screw.once you get the screw out put the chuck in a vice . you will need to squeeze it very tight. then put the drill in reverse and pull the trigger.if i wont come off you will need to hit the chuck with a hammer while you are holding the trigger. if you have a bit stuck in the chuck and cant get it out put the chuck in the vice and hit it very hard with a hammer until the chuck falls apart.i work on drills every day ,this is the only way we have found that works
May 30, 2009 | Milwaukee 0612-20 14.4v Cordless Drill Kit...
Porter Cable Cable 14.4 Volt Cordless Drill/Driver Kit 9824 Logo
332 people viewed this question
Top Porter Cable Drills Experts
LINDEN DAVIES
Level 1 Expert
Tom Chichester
Steve P
Steve P
Are you a Porter Cable Drill Expert? Answer questions, earn points and help others
