Question about ASUS Intel 850 Chipset P4T-E (P4T-E/WOA) Motherboard
Motherboard does not boot
No RAM beep when I remove RAM so it does not make it to the first phase after power test. (green LED is on).
based on the reactions I plan to do visual inspection or look for a replacement.
  • 416 Answers
Seems to me you have a motherboard issue
Posted on Jul 03, 2009
Unit will not power up. Still no power I have replaced the power supply, the power cord and tested the switch, I only have one green light on the motherboard. Nothing works, no lights, no beeps, no fans....
when motherboard or processor die, the fan can still on (blow), have you check your cable power led (a cable that connected your motherboard to power button?
May 12, 2011 | Dell Dimension 3000 PC Desktop
Please help me to identify my problem
The system beeps when you remove the RAM. This means that POST is working correctly and the motherboard may be fine.
Check that the monitor cable connector that connects to the video card isn't loosely connected.
When you insert the RAM, there's no display. This may mean that the RAM is detected but still faulty. Try using another RAM, if you can. Also remove the Video card (if you have a separate video card). Then, re-insert it firmly, and power up the system once again.
If you don't have a separate video card, you should test the motherboard on the bench, that is outside the computer case. Remove the motherboard, RAM and power supply (and the video card if it's separate). Put it on the bench and power it up as shown here:
http://picasaweb.google.com/raspal.century/MotherboardOnBench#
You'd need to closely look on the motherboard to see which pins are for the power switch (marked as PW-SW, PWR, PWR-SW, PWR-ON etc). Then, short them with a screw driver, for a second, to turn the system ON.
Replace the RAM and the video card one by one, if the system doesn't give any display even on the bench. This way you can find out what is the problem.
Hope that helps,
Regards,
Raspal
Mar 26, 2010 | Intel D845GVSR Motherboard
Packard Bell IMedia 5055: GA-8SIML will not post or boot. Removed all PCI cards,RAM,Hard drive, optical drives etc. Only CPU and mobo but no post/BIOS screen. CPU fan runs and front panel LEDs work. Do get...
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
Feb 04, 2010 | Gigabyte GA-8SIML Motherboard
Green light next to power button stays on - no response from computer, totally frozen for up to 12 hrs, then green light goes off, computer suddenly comes on for 5-10 min then freezes again.
Good day sir, hi, You need a thorough check on your PC.
But first try testing the Motherboard, Processor and Memory module.
As this point you need a friend, that knows how to tinker with your PC
Or you may need to do this.
1. memory testing:
Try replacing a new memory ram module on your PC, get the modules out of the memory slot, and let it be tested on another PC. if good,
2. power supply
Test for the power supply box, remove the 20/24 pin power connector from the mainboard and short the green and any black wire, your fan should blow out air.
3. Test for motherboard.
remove all coonections from the motherboard, except the 20/24 pin power connector, and the 12v 4-pin molex power connector, connect the pc speaker or the thumb speaker on the speaker port, connect a keyboard, clear the CMOS, (or remove the battery temporarily), connect the header panel (power switch, reset, power led) place the processor and memory (the tested good one). power on.
You should hear a beep (good) The keyboard will light up the three leds, then a few seconds, the numlock led.
If you hear 1 long and 2 or 3 short beeps, problem with the display section. Reseat any graphics card. test again.
If you hear continous beeps, reseat the memory, if the beeping persist, replace your motherboard.
If you hear nothing? only fan blowing, replace your motherboard.
I can only give you instructions, you need a someone who knows how to service a PC.
Dec 17, 2009 | Compaq Presario 5000 PC Desktop
My computer doesn't load on the screen as I turn it in
A solid amber power LED on a Dell System is indicative of a no post. There are 4 diagnostics LEDs on most Dell Towers (Either on the back marked ABCD, or on the front marked 1234) they can give more details of what the POST problem is.
Troubleshooting: Disconnect all external connections to tower except power, turn it on, see if the LED indications changed. If they change, then connect disconnected items one at a time till the failed item is found. If no change, the open tower, remove all PCI expansion cards, see if system will boot. If still no change, then most likely a motherboard failure. Take RAM out, see if you get a Beep error code when powered on, if no beeps, replace motherboard. If it does beep, try RAM modules one at a time, if it boots with 1 but not the other, replace the effected module. If no boot, with either replace MB
Oct 08, 2009 | Dell E173FPb 17" TFT LCD Monitor
Intel D815EEA: Won't Boot / Blank Screen / Three Beeps
3 short beeps means Base 64K RAM failure.
try to replace the RAM.
Jun 24, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
The phase 4 led on my gigabyte ep43-ud3l ights up
hi..the mother is need a complete the supply on board pin..then double cheek the memory..thanks..Good Luck...^_^
May 13, 2009 | Intel Motherboard
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
No boot up, display, beep, or HD action
I am having the same issue. Clearing/reset the bios will get the board to boot up, but when turned off and started again the board will not boot. you will have to clear the bios again. The board seems to be rebooting itself continuously before it evens get to the POST.
Jun 28, 2008 | EliteGroup P4M800PRO-M Motherboard
ASUS Intel 850 Chipset P4T-E (P4T-E/WOA) Motherboard Logo
194 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
