Question about Toshiba Satellite A10-S129 Notebook
Have a Emachine Laptop M6809 , the screen is all pixelated and distorted from bios boot through WinXP loading , same with external monitor .
  • 94 Answers
Theres a problem with the video card of your laptop. If you just formatted your laptop, check if you have installed the driver of your video card. Or bring it to the service center if you still have a warranty for it.
Posted on Jul 03, 2009
My ASUS Z99E laptop cannot access winXP
Try to access the BIOS "F2" Key, Go to the BOOT Section, set the 1st Boot device to DVD / CD Rom. Press "F10" Save and Exit. If it fails again, re-enter the BIOS. Then make sure the drive is set to IDE and not ACHI. press "F10" save and exit the BIOS. If that fails then select in the BIOS Load Setup Defaults, and re-select the boot device to DVD/ CD Rom.
If all fails, you have to open the side or bottom cover to remove the HDD - Hard Disk Drive, Connect it to a Stand alone pc via the SATA Cable or External Device (Works as USB) then you can either do an emergencey back-up, Format the drive through windows.
Hope it helps
Mar 23, 2014 | ASUS Z99E COMPATIBLE LAPTOP LCD SCREEN 141...
I tried to clean the dell vostro 1014 fan, after i assembled the fan and turned on the laptop it appear black screen with dim image on my laptop screen, When I plug in external monitor it shows boot s
It sounsd like your GPU may be BGA chip and would require a re-flow/re-ball if your laptop shows graphical distortion on both monitors.
However I would first try taking the laptop apart again and double check you have connected everything properly.
Mar 20, 2014 | Dell Vostro 1014 Laptop Computer
Hi, I'm installing widows xp in HP Compaq nc6220, but after setup loading files the mesaage (bottom of setup screen) "Setup is starting windows", then it did'nt contiue the installation,...
1 many times the the CD cant load as the files in the CD are corrupt or the CD is not read by the drive corectly...so get a new WinXP CD
2 try an external CD drive if your BIOS alows to boot from USB drive....(connect the external CD drive to the USB and make necessary changes to the BIOS boot seq in the BIOS screen...
BIOS screen can be enabled by pressing the F1, or F2 or the Del key as on as you start the PC
3 once in BIOS screen look for boot seq and change the boot drive to the foll
1st boot device - USB CD / DVD rom drive
2nd boot device - internal CD rom drive
and so on
if you can do the above then try the WinXP installation using the external CD rom drive....
else there is a little complicated method of using a pen drive thru USB (will discuss that later) provided your BIOS alows booting from USB
for more PC related issues visit my website
reg
kris
suresh_krishnan1961@yahoo.com
www.sureshayyar.110mb.com
May 18, 2011 | HP Compaq nc6220 Notebook
I was using an external monitor (emachine E19T6W HD ready monitor) as the primary screen with my Compaq Presario V6000 laptop. I think the cable must have disconnected but because the external monitor was...
Press the FN key and the Key with a small monitor on it. Usually F6 or F7 on most laptop keyboards. You might need to do it once or twice until the screen flickers and comes back.
Please Rate. Thank you.
Apr 03, 2011 | Computers & Internet
How to fix emachines netbook , model 250-1162 the 10.1 LED LCD screen will not turn on
Is it the screen or the laptop?
Have you plugged an external monitor to see if its booting?
If it is booting with an external monitor, you may need a replacement screen (google your model and replacement screen)
If its not booting, you could try this.....
http://www.fixya.com/support/r5335055-unable_start_windows
Jul 18, 2010 | Acer eMachines eM2501162 Netbook
Toshiba Satellite A100 PSAA2C video boot
have you tried installing or running the drivers disc for your laptop right after the windows installation without restarting it first? that might do the trick... it's either the driver for your laptop's board/ chipset or the vga driver...
Nov 08, 2009 | Toshiba Satellite A100-S8111TD Notebook
Computer loading/splash screen pixilated and distorted
if you can, hook the computer up to a different monitor and see if it does the same thing. It sounds like it is an issue with your monitor initalizing but the reboot can complicate things. Also if you have a cd that came with the computer you might want to put it in and see if you can re-install your video drivers. One last thing is to check and see if the reboot might have changed some of the settings on the monitor itself. See if you can reset to factory default or an auto adjust. It depends on the kind of monitor as to wich option you can do
Jan 02, 2009 | Computers & Internet
Screen goes blank after booted up
try replacing the memory module on the laptop as the resources on the memory is shared with the graphix
Nov 26, 2008 | Gateway Emachine Bestec ATX-250-12E PS...
Desktop scree showing white bright spots
The bright spots which you are seeing my be the failed pixels on the screen.
Once connect the external monitor to the notebook and check the display on the external display.
If you don't have external monitor, then restart the notebook and Press F10 or F2 key to Enter into BIOS. If the screen is same with bright pixels in the BIOS screen, then the it is confirmed the issues is with bad pixels.
If your notebook is under warranty, then HP will arrange for mail-in.
Note: There is Pixel policy from HP, go through thebelow URL:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00288895
Aug 03, 2008 | HP Compaq Presario v3000z Notebook
Acer aspire 3000
Have you tried to disconnect the external monitor and just booting to the laptop? If this works, then use the "e" key next to the power button to add the second monitor.
Jun 20, 2008 | Acer Aspire 3000 Notebook
Toshiba Satellite A10-S129 Notebook Logo
182 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
