Home | HP | LaserJet 1020 Printer | I am unable to print an ...
HP LaserJet 1020 Printer
Problem for HP LaserJet 1020 Printer
I am unable to print an address on an envelope....
By mhull219 on Jul 03, 2009
I am unable to print an address on an envelope.... it comes out blank
Sponsored Links
Solution #1
posted on Jul 03, 2009
Not Rated)
buddymc
Rank: Guru  HP Expert Computer Hardware  Expert
Rating: 94%, 282 votes
It sounds like to paper setting is wrong. In the configuration you can set if the envelope in on the right side, left side or center of the paper feed. If it is set one way and you feed the envelope the other way the printer will print but on the wrong end of the feed area so nothing will be on the envelope. Try this, print an address label as you would on the envelope but just use a full sheet of paper. If it prints where you can see it, then feed the envelope on that side, or change the feed settings in your software to print on the other side. Office and most other programs have this setting. In MS word the orientation setting is on the envelope and label screen on the right side of the pop up box.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Was this helpful?
Yes
No
Popular Solutions for HP LaserJet 1020 Printer
Questions and Unsolved Problems for HP LaserJet 1020 Printer
Do you recommend HP LaserJet 1020 Printer?
Answer
Answer
my hp 1020 laser printer always prints out these ink blobs on the pages, can someone help please?... (More)
Answer
where should i get hp printer driver rpm for linux5
Answer
the printer will not pick the paper from the lower tray. It tries to pick the paper from the upper... (More)
Answer
Suddenly my printer fall out , without a specific reason . I changed cartridge with a new one, I... (More)
Answer
I have an HP1020 printer that flat out will not print. It has worked rock-solid for a number of... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP LaserJet 1020 Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 1417
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
