My motherboard is mixed components i have no information abt my motherboard i need to know abt the sound drives required for my motherboard
  • 94 Answers
Try to look for the model of your motherboard written in the board itself. Or Go to Start menu, go to Run and then type DXDIAG. You will also see there the Model of your motherboard. When you get the Exact model of your motherboard, you can now search the internet the drivers of the built in peripherals in your motherboard.
Posted on Jul 03, 2009
How to build a or assemble a computer and troubleshoot?
Building a computer will require: a motherboard, a processor, memory, a video card or motherboard with onboard video, a sound card or motherboard with onboard sound, at least one hard drive, a CD or DVD drive, a case for the computer components, a power supply, fans to cool the computer, an operating system, a monitor, speakers, keyboard, mouse, 2-3 hours to assemble the computer.
You must ensure that all of the components are compatible with one another. After receiving the parts, lay everything out on a large, clean surface. Make sure you are grounded by touching a metal surface; this will prevent the transfer of static electricity to your computer components.
Typically, the steps to install the components are as follows: 1. mount the power supply in the case, 2. mount the motherboard 3. lock the processor in the socket on the motherboard 4. insert the memory sticks into the slots on the motherboard 5. mount the processor fan on the processor 6. insert the video card into the applicable slot on the motherboard 7. insert the hard drive into a hard drive bay in the case, 8. insert the CD drive into a CD drive bay, 9. mount any fans you have to the fan cutouts on the case 10. connect all applicable data cables to the CD and hard drives 11. connect all applicable power cables to the motherboard, video card, processor, hard drive, CD drive, and any other components. 12. connect the front panel USB, power, lights, and reset connectors to the motherboard 13. close the case 14. connect the power, monitor, speakers, keyboard, and mouse to the computer
Because this process is rather involved, I recommend following a guide such as this one: http://www.maximumpc.com/article/how-tos/how-_build_silent_gaming_pc
It details the process, includes pictures, and even provides a list of compatible parts.
Jun 19, 2011 | Computers & Internet
I developed a problem with my hard drive and needs your help. My seagate 1 tb is not responding. It gives me an error any time i try opening it. The error says I/O device not accessible. I have tried...
sounds the drive is failing. you can try to connect it externally via USb if is currently an internal type and try to get your data that way. you can also search free data recovery tools that may help or get professional data recovery service for a fee available in your area. hope this helps
May 15, 2011 | Computers & Internet
Hi there! I have a problem with my sound drivers. I don't seem to be able to properly install correct sound drivers into my system. Please assist me by giving me a set-by-step kinda procedure. I...
This needs more information before I can help. I need to know the following information:
- What Operating System is it?
- What Sound Card is it?
With that information I can guide you on how to obtain and install the required software.
Apr 01, 2011 | Matsonic MS9158E+ Motherboard
How can i get information abt drivers of my motherboard sound and video driver
try the solution here
http://pcmediks.blogspot.com/2010/10/how-to-find-drivers-for-unknown-device.html
Nov 10, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I have core due 2.5ghz with intel mother board dg31pr i have installed window xp2006 now i required drivers for graphics, sound and lan and all other drivers according to my motherboard requirement.
You should have got a drivers CD when you got his motherboard, if not go to the Intel website on another computer and download the drivers onto a pen drive and then put them on.
Hope this helped, let me know if you need more information.
Thanks
Jason
Oct 14, 2010 | Intel DG31PR Motherboard
I turn on the computer and it does not load or nothing. the only thing that lights up is the hard drive light and it stays on.
I don't know how computer technical you are, but it sounds like you know a thing or two about them. So here's the best way to find the problem:
There could be many things that could stop the board from fully booting, Determining what is wrong is like detective work. What I do, is open up the case and take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd, harddrive or otherwise) the CPU, a graphics card (only if required) and one bank of memory. (which is not required, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. If your going to load a ide drive, make sure you set your pin setting correctly on it, meaning the drive (IDE or EIDE) your putting on the board is set to Master, or Cable Select if your using the cable placement method.
Now, turn it on, and you should get the power supply on, and the cpu fan going. If they start, then make the next step to have the single drive be your hard drive, and see if it boots. If it boots, then great, open Bios and make sure Bios is reading the board and all things are fine with it. If so, what ever you put on next make sure it one at a time so you can identify what it doesn't like.
In the situation where the CPU or power supply don't power up, it's then either one of the first elements. The CPU, Power supply, Ram, Drive, graphics card (if required) or the motherboard.
The next step is to replace each one of the first five, starting with the Ram Chip, put another like chip in and see the results. Then do the same thing to each of the remaining 4 components, the graphics card (if required), then the drive(cd, harddrive or otherwise), on to the CPU, and last the power supply. Hopefully something will show it's ugly way to make a change. Also, on the drive (IDE, EIDE or SATA) , try a different cable to make sure it's not that, Most people say that they don't have additional components to do this with. I understand, but if you replaced something like a new hard drive, then you probably still have the old one. In most cases you might have a friend (Geek) that might have some spare components. If not, then you may have to make an investment at the local try's or computer store. Keep the reciept so once you find out what it is, you can return the rest of the stuff you don't need.
Now If no changes happen after all that, then I take it one step futher and usually get a like (doesn't have to be exactly the same, just capatible with the components so they can be tested on) motherboard that I can test the first four, and make sure that they really work. If after that and you have tested all of the components and they all work, then it's save to say you have a bad motherboard my friend. It's a lot of work I know, but it's the sure fire way of finding out what isn't working.
Good Luck
May 14, 2010 | MSI K8MM-V Motherboard
I dont know much abt motherboard..but my audio device is not detected so can u just temme abt the audio jumpers..
eh no but u can use the comms jumper 2 reset the comms on the board then check its registering in the bios
Jan 01, 2010 | Computers & Internet
Sound card
A sound card (also known as an audio card) is a computer expansion card that facilitates the input and output of audio signals to/from a computer under control of computer programs. Typical uses ofsound cards include providing the audio component for multimediaapplications such as music composition, editing video or audio,presentation/education, and entertainment (games). Many computers havesound capabilities built in, while others require additional expansioncards to provide for audio capability.
There is more information on this here
http://en.wikipedia.org/wiki/Sound_card
Jan 15, 2009 | Intel Motherboard
My desk top hv no sound
ur motherboard has a disk containing the drivers needed for components like the vga card.. sound card (if integrated onto the motherboard), local area network (LAN) etc..to work.. this disk probably came along with ur computer.. unfortunately.. when you formatted th hard drive and reinstalled windows u got rid of all these drivers and they must be re-installed in order for these components to work..
if there is no disk present you can download drivers straight from the manufacturers website by typing in th make and model name of the sound card..or of the motherboard if p.c has a soundcard integrated onto the motherboard) into the address bar (the bar at the top normally..this begins with http://) you can find these details by going to start > all progs > system tools > system information > components > sound.. this will display the name and model etc of th card.. once on the manufacturers website there is usually a link for downloads to follow..
alternatively go to start > control panel > system > hardware > open "device manager" > once open look in the list for any yellow explanation marks anywhere..right click on any item showing this and delete..then restart the pc.. once it has restarted th pc will automatically detect new hardware and look for drivers.. often the best move now would be to rollback the drivers when given the option but this wont work after a disk format because th format clears th hard drive of everything..including updates and drivers so.. if you DO have a disk supplied with your pc carrying the required drivers (most new pc's will have this supplied with several other disks required to install software or applications...... this is far the easiest method of installing drivers
Nov 23, 2008 | Trust Ever 32bit 4-Channel PCI Sound Card...
Need information please
This mainboard supports UltraDMA 66/100. UDMA is a technology that accel-erates the performance of devices in the IDE channel. To maximize performance, install IDE devices that support UDMA and use 80-pin IDE ca-bles that support UDMA 66/100.
Feb 25, 2008 | EliteGroup K7S5A Pro Motherboard
Computers & Internet Logo
37 people viewed this question
Alun Cox
David Payne
David Payne
