Question about Mitsubishi WS-48613 48" Rear Projection Television
Mitsubishi Power Problem -turns itself off.
I got this TV in June 2000 but didn't use it much.
Model VS45607 (it's a 150 pound unit--hard to move)
Wife bought it for about $1500.
Can't turn it on from the remote. When turned on from TV, the TV immediately turns itself off. (Click Click)
A month before this happened, the tuner worked only intermittently--some channel signals didn't show, some channels displayed on multiple channels.
I'm tech savvy; sent an email to Mitsubishi to see if a repair manual was available. Opened the back: Nothing obvious (blown components, etc. Nothing smells.)
A local repair company will come out to look for $135; if I do the repair, the $100 counts toward the labor. I'm wondering if it's even worth fixing.
  • tekmark Nov 22, 2007
    Thanks for trying--this didn't help. The circuit board is spotless.
  • 1,694 Answers
Sounds like CRT coolant leak onto signal board = check
for work....................................................T.
Posted on Nov 12, 2007
  • Vista Electronics Nov 12, 2007
    = check for wet, I mean.........
    Ps. Please rate accordingly..............Let me know if you
    want to pursue repair.........T.
HI there,
Check for any bad solder on the mainboard of the TV, and also check for any burn fuse on the powersupply area... BAd solder was very common problem on Mitsubishi TV..
Jun 07, 2008 | Mitsubishi VS-60607 TV
My Mitsubishi DLP WD-73873 model television only powers up when I press the Menu and Input buttons simultaneously. The tv also will power up by itself occasionally. Anyone having a similar problem?
  1. Yes, this happened to my Samsung. It was the high voltage circuit on the power power. The TV has a chip that check all the circuits on all three boards. When a circuit is low, then it won't turn on. I checked 380 volts at the capacitor connected to the high voltage transformer. It should have been at 390 volts. I took out the 100 uf rated at 450 volts, but only have two capacitors lying around: 150 uf and 220 uf rated at 400 v. I connected them in parallel make them 370 uf at 400 volts, and the TV is now working fine.
Dec 21, 2017 | Mitsubishi Televison & Video
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
Mitsubishi DLP TV model WD-65100. Power not ON
What about Lamp Fan if it is defective lamp will not turn on and if Ballast Board is not working then Lamp itself will not power on. Encompass has parts for this TV 1-800-638-3328
Feb 09, 2010 | Televison & Video
Power interruption model vs 60607
These units have had issues with the Yoke plug connections on the Yokes being intermitent. I would advise only a professional to check it out.
Hope this helps,
Jul 04, 2009 | Mitsubishi VS-60607 TV
Won't turn on tv - see side description
The Horiz Out Trans "HOT" #J6920 is shorted command for this unit replace with part # 0502-001230. Before you do that check the main fuse.
May 14, 2009 | Samsung Televison & Video
Code 22, will not power up.
i found you a manual :)
from here select
CRT televisions, year:2003, then your model, and click pdf :)
Nov 19, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi Projection TV Model # VS-50502
The power supply section is having trouble.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Feb 13, 2008 | Mitsubishi VS-50502 50" Rear Projection...
Power turns off automatically
happened with my 2002 42" model. they say the convergence circuit.
Mar 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi WS-48613 48" Rear Projection Television Logo
104 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
