Question about Sears TGE MP3 Player
Will not charge.
My unit will not recharge. I have contacted tech support and their suggestion was to press the EQ button for a long time to unlock the player. I tried this, there was a little icon that looked like a lock and it did go away when I pressed the EQ button but the player still will not charge. The battery appears to be charging when I hook it up but when I unplug it after leaving it plugged in all night or two days it still gives me the low battery message and turns itself off.
  • 4 more comments
  • terry32 Dec 28, 2007
    same problem , i have two and one will charge and one won't no matter how long or what else you try
  • Anonymous Dec 28, 2007
  • Anonymous Dec 29, 2007
    same problem - charged all night and still says low battery
  • Anonymous Jan 02, 2008
    I too have left my player plugged in for days and it STILL indicates a low battery. EQ button is NOT a solution.
  • Anonymous Oct 19, 2008
    it wont charge no matter what so open it up and charge the battery manualy like hook up the correct power source directly to da battery i have the same problem
  • Anonymous Nov 30, 2008
    I have a tge mp4 player that recharged the first few times and now won't.
Turn it on then charge it
Posted on Dec 11, 2007
My phone is display out of range
  1. hi..
  2. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
Jan 03, 2011 | Uniden Cordless Phone
How to charge
Which model of Robinair machine you are using ? If it's 34700Z then follow as: After Recover & Vacuum, Press "CHARGE" button on contro panel & add the amoun you want to charge then press ''YES" button.
Jun 16, 2010 | Robinair Cool Tech 34700Z Recovery,...
press the power button several times while player is connected via USB, waiting a few seconds between, eventually it will start charging, took pressing power on mine 5-6 times till it eventually started charging.
Aug 10, 2009 | Memorex MMP8565 MP3 Player
Flip ultra hd not charging
I had the same problem, but it seemed to be a bit more sporadic. I'd occasionally get the "Charging Paused - Check Battery Pack" error. The battery pack itself looks a bit strange, since the white plastic covers the bottom, right side and it seems that there is no possible way for the battery to make contact with the camera. However, I saw the following suggestion on another site (which the poster claimed came from Flip technical support), and this technique worked for me:
1) remove the battery pack from the camcorder
2) connect the camcorder to a powered USB port on your computer
3) when the "Connected" indicator comes on, insert the battery pack into the camcorder
4) safe eject your camcorder from your computer
5) reconnect your camcorder to your computer
6) the battery pack should now begin to charge within the camcorder
May 20, 2009 | Pure Digital Flip Video Ultra Camcorder
Custom eq problem
Contact Sansa tech support directly to inform
May 23, 2007 | SanDisk Sansa e260 MP3 Player
Signal indicator flashes constantly
The following worked when I had what appears to be the same problem. Solution :- Remove batteries, remove power connection, wait 30 minutes, re-connect power and replace batteries then press button on base until it beeps. Both handsets started continuous beeping which eventually stopped and everything was returned to normal. Admittdly this sounds almost identical to the process used by 'versailles' above, but at least it confirms that the technical info given by the BT Helpline does work
Nov 28, 2006 | British Telecom Freestyle 2200 Trio...
Sears TGE MP3 Player Logo
69 people viewed this question
Top Sears Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
ray gallant
Are you a Sears Audio Player and Recorder Expert? Answer questions, earn points and help others
