Question about Whirlpool Calypso GVW9959K Top Load Washer
Wshing machine panel shows the numbers 28 and will not shut off.
I had just finished doing a wash when the number 28 showd up and now the machine will not operate. I have tried shutting it down and still the problem exists. Please help.
  • 39 Answers
Any model number and brand name??? it would help!!
Posted on Jul 03, 2009
Sears washer elite he3 fills back up with water when off
You have to shut your wall inlet pipe after your wash is over. If the leak persists you only have to change the inlet valve, which you can do yourself, see internet for spares quoting your washer number, model. It is good to keep the valve closed when the machine has finished it's wash.
For unlocking hold down "end of cycle" button at right side of panel for 3 - 5 seconds. The door remains locked when there is water in the machine, it does not want to wet your floor. Today's machines are smart. Helped?
Mar 05, 2013 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Hi! my GE wshing machine keeps filling with water but the wash cycle wont work. the tub isn't roating. it will advance to drain and spin if i manually do it.
sounds like the pressure switch line is plugged. remove the front panel by inserting a putty knife between the front panel and the main top an inch or so from either side to release the locking tabs. the clear tube to the left side needs to be removed and cleaned thoroughly, while the tube is removed begin filling the unit with hot water untill water comes out of the spout the tube came off of. reinstall the tube and test to make sure the water level shuts off at all levels. the largest level should stop right around the top level of tub holes.
Feb 08, 2010 | GE WBSR3140DW Top Load Washer
Wshing machine operates but does not rinse and speen.
Try cleaning the filter if its not pumping out water this causes no rinse / spin
Oct 02, 2009 | Washing Machines
Maytag wshing machine just stopped working, won't turn back on
Open the top console panel to access the spin/start switch and reset the start switch. If that does not work, replace the start switch.
Jul 11, 2009 | Maytag Dependable Care LAT9706
Stuck on drain cycle
Same problem with ours and definately appears to be board.
Cant find board anywhere on Google by searching all various stickers and etched numbers on board
Apr 29, 2009 | Washing Machines
Water keeps running into the tube after it shuts off, and finishe
Replace the inlet water valve. (the part the hoses screw onto) If you confirm your model number, I can provide you with the part number. (get the number off the model sticker from the machine)
Feb 26, 2009 | GE WBSR3140DW Top Load Washer
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Candy Activa Smart 1300 AA
Click on your model number above, (below FIXYA) on this site, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Jan 25, 2008 | Candy AQ130 Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
88 people viewed this question
Dan Webster
Dan Webster
Sal De
