Question about Lexmark T640dtn Printer
I have a 917 transfer roll error on a lexmark t640 i have replaced the roller and the error is still there any ideas ?
  • Lexmark Master
  • 1,684 Answers
You may have a high voltage power supply problem. Here is the info from the service manual about that error.
Check the voltage at J15-3. The voltage changes from +24 V dc with the printer idle to 0 V dc when the printer runs the print test. If the voltage is incorrect, check the continuity of line J15-3 in the front cable harness to the HVPS. If there is no continuity, replace the cable harness. If there is continuity, replace the HVPS. If the problem continues, replace the system board.
Your error message diag/repair is a bit involved. If you need a service manual we have them in available for $6.95 in electronic form. W also have repair parts in stock for this unit, email me if you need parts prices.
I hope this helps you, if so please rate my solution.
Buddy
Corporate Computer
WWW.CCL-LA.COM
Posted on Jul 03, 2009
What is the service transfer roll? What does it look like? How do I replace it for the classroom printer?
Most often caused by high voltage power supply caused by toner spill. It is located bellow the transfer roller under the paper guide.
Oct 18, 2013 | Lexmark T640 Laser Printer
Service transfer roll
Hi, The transfer roller is the roller located untherneath the tonercartridge. Partnumber 40X0130
Printer displays 917.00 print error. seems to be transfer roller. changed the transfer roller same error.
The exact definition of this error is "Problem with transfer-transfer servo start error"... NOT the transfer roller. The service manual directs you to the Transfer roll service check.
The service check tests for proper operation of the HVSP, system board, and sensors.
The most likely cause of your problem is the HVSP ( High Voltage Power Supply ).
Change the HVPS and you should be good to go!
Feb 28, 2011 | Lexmark T640 Laser Printer
I received an message 917.00 service transfer roll. How do I fix this ?
Here's an article on A 917 or 917.00 Service Error Is Appearing on a Lexmark T640, T642, T644, or an X64xe Series Printer. Just click on this link: http://bit.ly/aQD8jS. Follow the recommended actions. If error won't clear, printer may require service. Don't hesitate to contact Lexmark technical support for assistance. Thanks.
Aug 06, 2010 | Lexmark T640 Laser Printer
91700 Service Transfer Roll was appearing on my screen so I ordered a new one replaced it and it is still showing me the error.
Here's an article in the Lexmark website to guide you on what to do when having 917.00 Service Transfer Roll error. Just click on this link: http://bit.ly/d7uyzZ. Follow the instructions carefully. Basically, when having this kind of error, you will need to primarily change the transfer roll or the High Voltage Power Supply. If this doesn't help, it may require service to replace the system board assembly, transfer roll left and right arm.
Jun 01, 2010 | Lexmark T640 Laser Printer
Lexmark T640 Error 917.00, I have changed the
you need to change the high voltage power supply to fix this error i have found this to be the problem 98% of the time and i do csome 1200+ repairs on these printers a year
Nov 27, 2009 | Lexmark T640 Laser Printer
Error code 917.00 "service transfer roller" won't clear
This is a transfer roll error. Take the toner cartridge out and clean the area under it. The transfer roll is a roller which is right under the toner cartridge. make sure the ie is clean . It may need to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 30, 2009 | Lexmark T640 Laser Printer
Lexmark t640 error message
"Remanufactured cartridges" How do you define that?
Given that Lexmark does not support or condone the use of third party products in their printers.
When a cartridge is new from the factory, all of the components inside the cartridge are new.
When Lexmark sell a recycled cartridge, all of the components within the cartridge are ETN components (Equivalent to new).
That means all of the rollers have been change and the PC is new.
It seems you purchased a cartridge which has a defect.
Return it to your point of sale and see what happens with the next one.
Don
May 29, 2009 | Lexmark T640 Laser Printer
Lexmark t644 error code 917.00
This error indicates that there is a charging problem with the transfer roller. You could start by cleaning the contacts for the transfer roller (power off printer first). The transfer roller is the black foam-like roller under the toner cartridge. Handle it with paper because the oils on your hand could damage it. To remove it, just pry under the far left side with a screwdriver. Lift and pull to the left to remove. If this does not fix it, then you have a more serious problem. It could be one of the arms or the HVPS.
May 07, 2009 | Lexmark T642 Laser Printer
Printer problem
Your transfer roller needs replacing.
Feb 22, 2008 | Lexmark T630 Laser Printer
Lexmark T640dtn Printer Logo
2,690 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
