Question about Maytag Washing Machines
Lat8406aae It is a maytag performa 2 speed washer and I need to know the wiring diagram for the motor. part number 6 2016660-16
IFIXALL
  • 868 Answers
SOURCE: Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Posted on May 23, 2008
dutchman05
  • 487 Answers
SOURCE: MAYTAG PERFORMA PAV1000
Follow LINK
Posted on Jun 21, 2008
  • 5 Answers
SOURCE: Old Maytag washer LA182 motor replacement
Neil,
I need to know if the motor came with a wiring diagram when it was purchased or did it just come by itself. You may have to learn how to read the wiring diagram that is stored inside the control panel.
Posted on Jun 23, 2008
MNfisherman
  • 11896 Answers
SOURCE: I'm abusing...I mean using an old maytag washer
Sounds correct. You may need the start capacitor or higher voltage or power supply
Posted on Aug 17, 2009
  • 41 Answers
SOURCE: MAYTAG PERFORMA MANUAL
try www.lpdlpd.co.uk
They deal with most maytags and are a very helpfull company.
John
Posted on Sep 03, 2009
'need wiring diagram for door latch on maytag performa model#pav2300. I have the part. Retired industrial electrician.
Not sure if this will paste here if not enter your model # at www.appliancehelponline.com the diagrams will come up on the right hand side.
May 03, 2010 | Maytag PAV2300 Top Load Washer
My washer doesn't wring the clothes fully.
It's not spinning fast enough because of a loose or worn belt on the motor. Post back with your model number and I may can find a diagram of your washer to help you.
Sep 04, 2009 | Maytag Performa PAV2200
My maytag dryer won't heat up
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor 2 heavy red wires (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 17, 2009 | Maytag Performa PAV2200
Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Sep 07, 2008 | Maytag Performa PAV2200
Neil,
Jun 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Installing washing machine motor P/N 35-5022, need wiring schematic to hook up to machine internals
Is there a white or black connector that clips on the motor switch? it should be an easy unplug and plug the new motor in.
I dont of any Manufacturer that uses single wire connectors any more.
Are you sure you got the correct motor?
Apr 22, 2008 | Maytag Legacy Series Top Load Washer
The black or brown connection block on the motor should be color coded to match the harness. If not you will need to remove the control panel and find the service guide sheet. This will give you the wiring diagram for the whole machine.
Jan 10, 2008 | Maytag Performa PAV2200
Maytag 2 speed replacement motor
you may have wrong part , post model serial , and part number that you have i will look them up
Nov 29, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
251 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
