When I set up window vista it didn't have any problem with sound, but if I set up window XP, it didn't have sound and I can't play media player as well. So now I try to find driver board. Is it the right decision? Please help me!
    President:
  • 942 Answers
If you are re-formatting your computer you need to install the motherboard driver, because if the driver is not install the sound, Lan and VGA does not work,
You can see the if the driver was not installed, by following this steps
Right click the my computer
Chose properties
Click hardware
Click device manager
Now you can observe if there is a yelloq Question mark, it means the  driver is not installed,
Good luck !!!
Regards
PCmania
Posted on Jul 03, 2009
  • 519 Answers
Yes it seems that Vista has the sound driver but not xp. You will have to determine what kind of sound card you have and download the xp driver from the internet.
Best wishes,
Graemevm
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Many video clips recorded by GZ-MG130 were stored in my old laptop (windows XP) and played well in with windows media player. 1)I have now transferred them to my new laptop ...
Hi Rajeeva.
To start try downloading updated codecs for Windows Media player, and install them onto the new laptop.
Use this link to download updated codes:Free-Codecs.com :: Download latest audio codecs
If that is not enough also update Windows Media Player on the new laptop. Link is below.
Windows Media Player 11.
Updating codecs should fix the problem already.
Jul 26, 2009 | JVC Everio GZ-MG130 Camcorder
Tip
How can i operate my media player if theres no audio
how can i get a driver for my mothebord cause it all started when i upgrade my windos xp to windows vista ultimate 2008 32bit after a long week of using vista i get encounter that my media player wont play asking me to insert my sound setting be installed again my son cant play all installed games kindly sent me the right driver. so that i can used my computer again
heres my motherbord is ecs l4vxa2 p4 ddr533
on Feb 11, 2009 | Pioneer ECS L4VXA2 P4(478)/VIA/FSB 533/8X...
Hi i have a western digital home edition 2 tb hard drive that now when i play an avi movie file i get sound and no picture or picture and no sound also these files play fine on windows media player so now...
> these files play fine on Windows Media Player
Then, continue to use Windows Media Player.
Or, tell us what alternative program that you use that gives "sound-and-no-picture" or "picture-and-no-sound".
What version of that program?
Windows XP? Vista? 7?
Any more "possibly-relevant" details ?
Feb 01, 2011 | Computers & Internet
I am not expert in computer,my sound from desktop when i start and when i play itunes,vlc media,media player its playing video but no sound it was working from last 4 years ****. please help
Have you changed anything in your settings or setup recently before you lost sound? What platform are you running? Windows 98, windows 2000, Windows XP Home, Windows XP Pro, Windows Vista, Windows 7? or something else
Jan 06, 2011 | Computers & Internet
CAnnot Play AVI files on my Windows Media Player
i would suggest either getting windows xp or 7, vista has alot of bugs
Jan 18, 2010 | Microsoft Windows Media Player
My sansa mp3 player isn`t recognized by the computer
It may depend on your operating system, but there are known issues in vista. There is also a hotfix from microsoft. This is from the Sansa Website FAQs at http://www.sansa.com/support/sansa_clip/faqs
My Sansa player is not recognized by my computer when I connect it.
The most common reason for this problem is not having the latest Windows Media Player installed, or having a Windows OS version that is not supported by the Sansa player.
The Sansa players support Windows XP SP2 and Windows Vista and above. If your operating system version is supported by the Sansa player:
SOLUTION 1 – Download and install the latest Windows Media Player
SOLUTION 2 – If that didn’t help, and you are running Windows Vista, apply the following hotfix - KB940199
SOLUTION 3 – If that didn’t help, download and Install the MTP Porting Kit (click here)
SOLUTION 4 – If that didn’t help, try connecting the device to the PC using MSC mode
On the Clip: Go to Settings > USB mode & choose MSC
I hope this helps and please don't forget to rate my answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Sandisk is not detected in Vista operating system notebook
See the FAQ here - http://www.sansa.com/support/sansa_view/faqs
View/c200: Turn on & press and hold the rewind button while plugging into the PC
Dec 30, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Sansa clip 2gb lockec
First of all, may I ask if you have a mini disc player or a Sansa Clip? Because the Sansa Clip does not play discs of any kind.
If you do indeed have a Sansa Clip you will find the FAQ rather helpful here - http://www.sansa.com/support/sansa_clip/faqs
Question 9 there is regarding devices not recognized by the PC and the solutions are as follows:
If none of the solutions work for you, please post the results of your attempts and we can go from there.
Dec 27, 2008 | Audio Players & Recorders
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
