Question about HP Pavilion dv6000z Notebook
My battery is not charging. it says 0%available plugged in not charging. i was wondering if there may be somthing i can do that can help or my charger in no good
    Master:
  • 404 Answers
If the laptop is over 1 year old and if the charger works without battery then it looks like you may need a new battery.
Posted on Jul 03, 2009
It shuts off all the time. Battery meter says....0% available (plugged in, charging) all the time.
If your computer stays on with the charger you might need a new battery. I had a similar problem with my Acer PC, it turns out all i needed was a new battery. After i purchased the new battery and the new charger my laptop work perfectly. Hope this helps. Good luck
Sep 30, 2013 | Toshiba Satellite Computers & Internet
Canon FS-10 camcorder battery
The battery may not be getting power, it is unlikely that many consumer available batteries exhibit behaviors like experiencing damage from complete depletion, try and charge it on another charger like a universal one, borrow a battery and see if you cam and charger charges it, lets make sure its the battery first, and if that is the issue find out why--Good Luck.
Jan 29, 2013 | Video Cameras
Power is plugged in , battery is plugged in not charging with 0% available
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Replacement Acer Aspire 6930 AC Adapter 90Watt 19V 4.74A
Nov 12, 2012 | Acer Aspire 6930 6930g 6930z 6930zg Laptop...
BATTERY SHOWING CHARGING, BUT SHOWING 0% AVAILABLE
This is an indication that the battery is dead. A dead battery won't accept any charge from a charger. If the laptop will operate when plugged in with or without the battery, it's a bad battery.
Nov 09, 2011 | Computers & Internet
I'm borrowing a Jet 3 Ultra from the local Am. Legion for my Mom to use. They know nothing about it except they were told it had a new battery. I plug it in and all the LED's light up with the...
The batteries need charging and when you plug in the charger and the power is on the lights wil flash indicating that the charger is plugged in. Now look at the rear of the chair near where the charger cord plugs into the chair and you should see a voltmeter. With the charger plugged in the voltmeter will indicate about 5-6 amps and after charging overnight the voltmeter should be reading 0 amps. If when you plug in the charger cord and the voltmeter indicates 0 amps then I would suspect that the charger is not working or that the fuse is blown in the charger circuit. The only way to see if the batteries charge would be to borrow or find an offboard charger that will plug into the charger port located under the front of the joystick and after charging for 10-12 hours see if the battery level lights show full charge Hope this helps
Jun 25, 2011 | Pride Used Mobility Jet 3 Power Wheel...
Battery discharge quickly, I have replaced new batteries and module control and problem still exist.
Don your charger is probably not charging the batteries. When you charge your chair overnite the charger should have a red and green light showing charge complete. When you first plug it in the lights should be red and yellow. If you are getting a red and green light when you first plug it in then there is a problem with the charger or with the charging circuit to the batteries. You should have a charger port on the battery box try plugging the charger into that port and see if you can get the batteries charged. When you do you should have a red and yellow light on the charger changing to red and green when fully charged. Hope this helps
Nov 07, 2010 | Pride Go Chair Travel Power Chair
Plug charger in and will not charge the fan on the charger quits running in a few seconds it will beep with charger pluged in and when you unhook charger it clicks like a dead battery i wonder if charger...
David Are you leaving the power on while you are charging the Chair? If you are try charging with power off at the joystick. The manufacturers of all power batteries do not recommend charging with automotive chargers. I would try to locate a friend or neighbor that also has a chair or scooter and borrowing their charger for a few hours to see if it will charge your chair. If not contact your provider and borrow a charger from them. If the different charger works then yours is bad. You shoud be able to order a charger through your provider or by calling Pride Mobility @ 1-800-800-8586 Hope this helps you PS I didn't say you couldn't use the "other" charger. But I wouldn't want you to think I approved of it
Oct 02, 2010 | Pride Jazzy 1103 Ultra Standard Power...
I can't charge my batteries. When I plug in with the batteries, it says "0% available (plugged in, not charging)" Any ideas?
Sounds to me like a problem with the charger. That would be your best bet anyway is to check and see if the unit that charges the batteries (or if its a power supply that plugs into the laptop) is putting out the correct voltage. The voltage is on the power supply or charger. You will of course need something that can check DC voltage.
Jun 14, 2009 | Computers & Internet
Laptop battery
Usually when it reads 0% it is a faulty battery, and when light does not come on, like there is no battery it is faulty battery charger.
Here you can buy the battery for $95, they start from $70 on Ebay, don't buy second hand:
HP Pavilion DV9408nr Battery $95.99
The laptop mounts same battery as DV9000 series.
Aug 31, 2008 | Computers & Internet
No power no charge
i think theres somthing is stuck in there chclk if not call sony
Jul 04, 2008 | Sony PlayStation Portable (PSP) Console
HP Pavilion dv6000z Notebook Logo
113 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
