Question about Electrolux Kenmore 24 in. Built-In Dishwasher with 5-level Precision Direct Water Delivery System Dishwasher
Wont drain hear clicking noise
Dishwasher will not drain hear clicking noise under it
    Brigadier General:
  • 8,619 Answers
Hi
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jul 03, 2009
My GE Triton dishwasher won't drain. How do I de-clog it?
Remove the dishwasher drain line from the under sink connection. Direct that end to a bucket and run the drain option on the dishwasher.
1. Does water drains to the bucket. Then your under sink hook up to the dishwasher is clogged. Clean it with a screw driver.
2. No drain water comes to the bucket then
2.1 When on drain do you hear a humming noise. If yes then your drain motor working. That means mostly your dishwasher drain line clogged.
2.2 If humming noise is like a fan (impeller) running then drain line clogged.
2.3 If humming noise is like a small struggling to run. Then something stuck in the drain motor impeller.
Apr 24, 2015 | GE Tritonr XL GSD6260JCC Dishwasher
Frigidare dishwasher wont drain, can hear pump motor start
Hi Mark, this is AP and I'm happy to assist you!
I understand you are having trouble with your dishwasher not draining and making odd noises. I would suggest checking the drain hose to ensure it has not become twisted or kinked. Even if the hose is not kinked make sure it has not fallen behind the dishwasher either as this can prevent draining. Additionally, you could check the filter at the bottom of the tub to make sure no debris has clogged the filter or disposal. Other than that the drain pump could be the culprit. If so, I would recommend a local authorized technician to come out and properly diagnose the dishwasher. I hope this information helps.
Mar 15, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Bottom dishwasher of fisher and paykel wont drain
Check the filter sump is clear and there are no blockages in the rotor cavity. If you hear the rotor noise when it is in drain cycle then blockage is inside the rotor or filter sump cavity. Assuming the top drawer is working ok, the drain hose at kitchen end might be ok. The drain hose within the drawer could also be an issue. Try to run the dishwasher with a Finish dishwasher cleaning kit (from super market) after following the instructions on the kit. First empty dishwasher with a small cup.
If the rotor is silent during drain cycle then you have a bigger problem - faulty rotor circuit.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
If you can close the door, turn the control to drain and, can hear the motor running; you have a clog under the pump screen in the back of the Dish Washer preventing the pump impeller from turning
if you hear nothing: reset the house circuit breaker.
to fix: while the DW is on turn off the DW house circuit breaker then remove the pump screen and, remove the broken glass etc. from the pump then: repower and, test.
May 18, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Loud vibrating/humming noise
Okay...based on the model number, this is a Frigidaire manufactured dishwasher. If you go to searspartsdirect.com and type in the your model number in the Search menu, you will find a useful illustration under the "Motor and Pump" heading. The drain pump is listed as item #60 in the drawing. Before you go through any major dis-assembly, check to make sure the pump is securely in place and not loose. Sometimes the pump comes loose from the mounting bracket and vibrates. Also, sure nothing is laying against it causing vibration noises (I've seen this before). If the solution is not that simple, remove the spray arm assembly inside the dishwasher and inspect all the debris traps under the spray arm assembly. The wash pump and drain pump sumps are located here. Check to make sure there's nothing obstructing the input to the drain pump. Lastly, if all else fails, remove the drain pump and inspect the impeller. If the you've inspected everything and still have the noise problem, replace the drain pump. The motor could possible be failing. The part number on the Sears website is 154580301 and costs about $40. Repairclinic.com has the same part listed as item #1257094 for $37.50 if you wish to do some comparable pricing.
I hope this helps you. If you need further assistance, please post back and let me know.
PS Even the quietest of all dishwashers will make some noise. However, if it has gotten to the point where you can hear it in the next room, you probably need to inspect to find the source of the problem. This is not true with all dishwasher manufacturers, but in many cases, the only difference between your "Quiet-Pack" line and regular low-end models is added insulation behind the door and lower panel to help quieten noise.
Apr 21, 2008 | Dishwashers
Maytag dishwasher wont start
Drain the water out of the dishwasher. The high water switch ius engaged, lowering the water will disengage.
Sep 10, 2007 | Maytag MDB7100AWB Dishwasher
Dishwasher will not drain water out
if plumbed in under the sink, check the spigot the drain hose goes to is not blocked - a common problem. if on drain you should be able to hear the drain pump working. if you hear a faint humming noise instead, then there is probably a foreign object stuck in pump. also check for blockage in the drain hose
May 06, 2007 | Hotpoint 24 in. HDA1000Z Built-in...
Clicking noise from under the dishwasher & Its a new dishwasher
Maggie, what you are hearing is probably the drain pump solenoid. At start the drain pump will get in to get rid of any water and purge the system. It's hard to tell without being there. I would call for service, it won't cost anything. Have the tech check the wash and drain pump assy. Catriver..post back.
Oct 28, 2006 | GE 24 in. GSD4060JSS Built-in Dishwasher
Electrolux Kenmore 24 in. Built-In Dishwasher with 5-level Precision Direct Water Delivery System Dishwasher Logo
416 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
