Question about Coldtech CFD3R Refrigerator Commercial
Broken hinge We have a Coldtech 3 door refrigerator that has a busted hinge. (upper left - if it matters) How does one fix this?
You can purchase a new hinge. We have access to all Ascend/Coldtech parts. Please forward your model and serial # to sales@cullincini.com. We would be happy to help out. Dante Cullincini
Posted on Aug 17, 2009
Squeaky door
Buy a spray can of silicone lubrication and spay the hinges wipe off any over spray rotate the door 3 -4 times also clean door seals thoroughly, repeat if necessary.
Mar 10, 2014 | Maytag MSD2756G Side by Side Refrigerator
What is the part number for the door seals on a coldtech model S3BRR-18-S
Your best bet is to contact them by phone or email, from this website:
http://www.coldtechcommercial.com/customer-care-page.html
There is also this statement posted on their Frequently Asked Questions page:
Our ColdTech Commercial products have the logo that is on the top, left-hand side of this web page. If it does not match then it is not one of our products. We can't speak for other companies.
There is another discontinued product-line called ColdTech that we have no affiliation with - confusing, I know. Our commercial refrigeration line launched Aug 1, 2011 and our thirteen digit serial numbers resemble this: 0111053500001.
Feb 11, 2012 | Coldtech S3BRR-18S Commercial Refrigerator
Yes the frige has been moved recently. How do I adjust the doors
By removing the upper hinge covers their is some adjustment that can be made by loosing screws for upper hinge and pulling or pushing door to the left/right.
Aug 11, 2011 | GE GSS25LGM Side by Side Refrigerator
Really Up Sh/t Creek With Fridge Door Hinge (broken bolt)
Put 2 lock washers under the remaining 2 screws and dont over tighten.
This should hold the door fine just do not over load the door.
Go to the hardware store and get 2 new hardened screws if you think you damaged the remaining 2 screws.
If they dont have any that will fit try an auto parts store.
Jan 05, 2010 | LG LBC22518 Bottom Freezer Refrigerator
The left side door has dropped and the piece that closes the gap between the two doors will not operate properly. It leaves the gap open and the refrigerator looses coolness. Need to know how to realign...
Check the lower hinge of that door for a broken closer cam. The upper hinge is adjustable and adjusting the corners in the front will shift the cabinet to align the door also.
Eric
Dec 11, 2009 | Samsung RF265AA Bottom Freezer French Door...
Coldtech freezer door reversal
http://www.ascendmfg.com/PDFs/CT/hdmanual.pdf
start at this web site and see if this manual will help. It has phone number on last page if you need to call them.
ColdTech is now Jimes Corp. Just Google you unit if what I have does not help enough.
Good luck to you.
Oct 21, 2009 | Coldtech 21 cu. ft. / 595 liter Commercial...
Right door is lower than the left how do i level doors
if the door is slightly off u need a shim that will fit or a couple of small washers over the lower door pin remove food from door and with help from someone -to help in removing door and replacing it - at the top of the door u will c the upper hinge pin remove cover if one remove the 3 hold down screws while supporting the door remove hinge lift door off lower pin place shims or washers on lower pin till desired height not more than 3/8 is advisable place door on if still to low remove door and remove lower hinge and slightly give it a bend or leave on and slightly bend up hinge when desired height reached replace door and reattach top hinge
Sep 24, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Top of refrigerator just inside the fridge door has condensate collecting and eventually dripping onto the floor. I "inherited" this fridge from previous tenant who SWEARS that it is was caused by a...
If the door pops open after you close it, or the door is hard to push closed, the door closing mechanism has probably failed. Make sure you check for the obvious things, such as something sticking out of one of the shelves or orange juice cans rolling around the door shelf area causing the door to bounce back open when the door is slammed.
If you notice any unusual sounds when the door is opening and closing, such as a clicking or grinding sound, your door closer is probably worn.
There are three common types of door closers used in domestic refrigerators and freezers. We list here all three, along with how to access each component in order to change it.
The most common door closers used today are small plastic cams mounted at the bottom of the refrigerator and freezer doors. When you open the door, you cause the door to climb up onto the lower cam. When the door is released, the incline helps the door shut. To view a common door cam kit, <a href=" http://www.repairclinic.com/0081.asp?RccPartID=1035 ">click here</a>. You can see how the upper and lower cams each have a hill and valley that work against each other to make the system work.
In order to change these, remove all food in the door, and remove the upper hinge in order to take the door off. Most hinges have a plastic cover that can be removed by prying up on it to expose the upper hinge screws. Usually, the cams mount with one screw -- one on the bottom hinge and the other on the outer door panel. On some models, the lower cam is riveted onto the lower hinge, and it's easier to purchase the lower hinge complete rather than try to drill out the old rivet.
If the cams you are replacing are for the freezer door that has a water line going through the middle of the cam, you not only have to remove the door but you must also disconnect the water line. Most water lines are fed through a channel in the door panel and clamped into place in the dispenser housing. Or, there may be a quick disconnect fitting behind the kick plate or apron on the unit. Once you've installed the new cams, you may want to put a light coating of lithium or silicone grease on the surfaces where the cams meet.
Another type of door closer is actually part of the upper hinge assembly itself. To view this style of closer <a href=" http://www.repairclinic.com/0081.asp?RccPartID=781123 ">click here</a>.
In order to change this style, pop off the hinge cover, and remove the screws that retain the upper hinge. From there, pry up on the hinge and pull it through the hole in the outer door panel. If the spring is broken and will not come through the hole, remove the inner door panel. This is a big job so you might want to remove the door and lay it on a flat surface. Fold back the door gasket and remove all the screws around the perimeter of the door until you can separate the inner door from the outer door to gain access to the hinge assembly.
A third type of door closer commonly used is one that is internally mounted to the outer door panel, and you must separate the inner and outer door panel to gain access to the closer. To view this type of closer <a href=" http://www.repairclinic.com/0081.asp?RccPartID=616347 ">click here</a>. In this style, the hinge pin actually goes through the closer. The hinge pin has a flat spot on each side of it that meshes with the cams on the closer. To view this style of hinge pin <a href=" http://www.repairclinic.com/0081.asp?RccPartID=641650">click here</a>. On some Sub Zero units, this closer is mounted to the lower portion of the door and removal of the inner door panel is not necessary.
May 05, 2009 | Refrigerators
GE refrigerator door problem (model TBX25PAYARWW)
Is sounds like you will have a broken or worn out or bent hinge. It may be a combination of the 3.
Dec 26, 2007 | GE Americana 15.6 Cu. Ft. Top-Freezer...
Coldtech CFD3R Refrigerator Commercial Logo
258 people viewed this question
Top Coldtech Refrigerators Experts
billconfused
Randy Justice
ray gallant
Are you a Coldtech Refrigerator Expert? Answer questions, earn points and help others
