Question about Watches
Driver Of Hp Printer 3920 Driver - Watches
    President:
  • 987 Answers
S149 will not start
You may need to reset it. Unfortunately, this can not be done without taking the unit apart. I fixed ours yesterday when the screen was blank, by replacing the internal battery. Part of that process is resetting the clock.
This might solve your problem and so, I have included my full instructions for replacing the battery.
You will need a small phillips screw driver, a paperclip and a new battery. ( a CR2032 works fine and can be bought anywhere)
Keep in mind, you will be handling some electronics, so keeping static discharges to a minimum is a good idea.
*Place the unit face down on a table.
*Remove the battery cover and batteries.
*Using tape, cover the two switch sliders located on the sides of the unit so they stay in place when you remove the back.
*Remove the three screws inside the battery bay and the four longer screws on the main body.
*Before you gently seperate the back from the front, take note of the two battery connections that are on the outer edge of the battery box and are opposite of the strap brackets. These will need to be coaxed through the plastic as you pull the back off. You will also need to manipulate/open the paper roll cover.
*Remove the back cover.
*The top circuit board and printer are connected to the lower circuit board and front cover by a white ribbon cable and wires to a switch. Gently lay the top circuit board and printer to the side, being careful not to unlpug the cables.
*Locate the battery, it is standing on edge. Note the orientation.
*Straighten the paperclip and make a hook so you can remove the battery.
*Install the new battery, taking care to not bend the connectors.
*A label on the inside of the back cover details the reset procedure. Locate the AC and + on the lower circuit board.
*Use the paperclip to make an electrical connection between those two points.
*Reassemble the unit in reverse fashion.
*Pay attention to the switches on the top circuit board and the slots they fit into. These are the black switch sliders that were taped to the side.
*The printer assembly should set into place.
*Reinstall the back cover, coaxing the battery connections through their respective holes.
I hope this solves your problem.
Apr 12, 2014 | Seiko S149 Stopwatch/Printer
Blank screen with a line. Why?
I have the same, assume the watch battery is gone. Handbook says the whole timer has to go to a dealer to replace the battery.. the printer batteries are easily replacable, I wonder why they made the watch battery such a costly deal?
Sep 06, 2011 | Seiko S149 Stopwatch/Printer
I have a seiko stop watch s129 that only has a streight line going through the middle of the screen horizontal
The LCD is having issues. The Seiko Service Center is the only place to repair this watch. Contact them at:
(800) 722-4452
Jan 19, 2011 | Seiko S149 Stopwatch with Built In Printer
Seiko Stop Watch S149 Stop watch has new batteries in and they are put in correctly but nothing shows up on the screen. The paper feeder works so it is getting power.
If you go to "www.sportscounters.com/seiko-s149-stopwatch-printer-all-in-one" you will see a telephone number, try calling them for advice.
(This problem is fairly common after replacing batteries, so I suspect that there is a procedure for resetting the timer.)
Feb 25, 2010 | Seiko S149 Stopwatch with Built In Printer
My seiko s149 with built in printer went blank the other day.
The S149 has 2 sets of batteries
1) 4 X AA for the printer
2) a round "button battery inside the unit for the clock.
Open up the unit, you will see that it takes either a 2450 or a 2032 depending on the model.
Nov 15, 2008 | Seiko S149 Stopwatch with Built In Printer
Dont have a cd to set up my lexmark 3300 series printer.
try the following link to download the driver, it also contains instructions to install: http://www.opendrivers.com/driver/242085/lexmark-3300-series-printer-fax-solutions-v1.0-windows-98-me-2000-xp-xp-x64-free-download.html
Nov 12, 2008 | Watches
Ultrak 499 printer
yes I still needed help on my Ultrak 499 printer
Feb 05, 2008 | Ultrak 499 Professional Stopwatch with...
Unable to turn on Integrated Webcam on HP laptop
do not no how to turn on my webcam. hp g61 laptop
Oct 27, 2007 | Watches
Watches Logo
104 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
