Question about Kenmore 63942 Dryer
Kenmore Dryer won't turn on
I was using the dryer and when I walked past the fuse box, I heard a clicking noise. The circuit breaker to the dryer was making the noise. About 30 minutes later, the dryer buzzed and the clothes were finished and all dry. I put in a second load. An hour later, the buzzer sounded and the clothes were hotter than usual. A couple of shirts were wrinkled bad. I went to put in one last load and the dryer wouldn't start. My wife was working in the bedroom where the fusebox is and she said she smelled something burning.
Also the dial turns by itself. I set it on 60 and push the start button nothing. But everynow and then I hear a little click at the dryer and it's now at the off position. A few minutes later, I hear another click. It's now turned more to the next off position and so on even without being on.
I went back and changed the circuit breaker, but the dryer still won't come on.
    President:
  • 942 Answers
Hi...
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Regards
PCmania
Posted on Jul 03, 2009
Frigidaire Affinity panel turns on (lights up), even counting down, but the dryer won't tumble or heat. Help?!
Hi margaretc920 - Often when a dryer turns but will not heat, it is because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the unit as well will experience this issue. The heater of a dryer requires 220 to 240 volts to operate. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If the issue persists, it could also potentially mean a number of other things: defective cord, wiring, control board or door switch. I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Jun 16, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
My kenmore 96292800 won't heat up
Here are the probable causes, listed my most common to least common:
1) The heating element has failed, likely burnt in two.
2) One of the "overheat thermostat switches" has failed. There are several, as few as 3 as many as 6.
3) A wire inside the machine has burned in two.
Usually it will be near the heating element.
4) At the place where the electric cord attaches to the dryer in the back, one to the wire connections is toasted, needs repair.
5) A circuit breaker in your "fuse box" has tripped and needs to be reset.
The fuse box may be in the garage, laundry room, basement, hall, or wherever.
If you wish to attempt to fix it yourself, a question to "fixya" might get someone to walk you through the steps.
You'd need tools and a testing machine.
Be blessed.
Feb 23, 2013 | Kenmore Dryers
My kenmore elite dryer model 110 63032102 won't turn on
Check the door switch. Push it by hand and you should hear it click. If no click is heard, replace the door switch with this part.
If the switch is OK, then the only other problem will be with the thermal fuse located on the rear of the machine. Here is a link to that part.
Oct 15, 2012 | Kenmore Elite HE4 Electric Dryer
My general electric heavy duty automatic electric dryer won't heat. Is there anything to try before replacing heater?
go to your fuse box and try replacing the 2 fuses for the dryer circuit or if you have a circuit breaker box shut off the breaker for the dryer and turn it back on and try the dryer again. I used to be an electrician and found double pole circuit breakers that have only one side tripped. alot of 220volt electric dryers use one circuit for the tumbler motor and the other circuit for the heating element
May 07, 2012 | GE Dryers
Have a kenmore dryer model 110.66912692. Wife was using it for multiple loads today and then it stopped working. You can hear the timer ticking, and the push to start button makes a click noise like it...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 22, 2010 | Dryers
Blowing breaker
hi. I can help you.
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jun 22, 2009 | Kenmore 63942 Dryer
Kenmore Ultra Care Dryer- Electric
Your dryer doesnt have a fuse. Your home breaker panel is the only protection it has..Check your circuit breaker box for a tripped breaker.
Oct 22, 2008 | Kenmore 62602 Electric Dryer
Kenmore 63942 Dryer Logo
275 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
