Question about Traxxas Rc Revo Nitro Monster Truck
Revo problems My revo starts to "hiccup" when its hot but fine when cold or cool.
    President:
  • 4,070 Answers
Try checking the auxillary fans if its working, replace it if its not. hope this helps
Posted on Jul 03, 2009
Did tune up but still acts like it's missing once in a while
skipped filters?
hiccup.s can be lots of things,
so tell when the hicup ,er misfire happens
hot or cold engine. ? or both.
at any speed. , only fast right foot?, or only wide open throttle?
only on hills. ?
so far , no miss at idle or slow speed.
Jan 26, 2014 | 1998 Jeep Wrangler
I have a 2000 Jetta 4 cylinder, 2.0 engine. It starts fine when it has not been started but once the engine gets hot and car is completely turned off it won't start. It sounds like it wants to start but...
Hi.. I had a very similar problem recoverrd to are workshop by the A.A around a month ago.
Exactly the same problem (left to cool started.? Once worm or hot engine just turning over ?)
Afdter reading all known folts and finding nothing to do with what I'd wanted. It took some time ?
Cutting it sort if found when I replaced a intermittent faulty fuel relay and run till engine hot (untill cooling fan cut in) Then turned off engine .. on turning key to see if this had cured my problem?
The engine started frist turn of key after repeating this a number of times .. this car was now starting fine (whether hot or cold)
Problem fixed..
Hopefully this will be of some help to yourselves
Hears hopping
Don Milward Premier Garages
Sep 22, 2017 | 2000 Volkswagen Jetta TDI
Honda Super 4 CB400 coolant system hiccups
There seems to be an airlock in the system, as for the thermostate you can remove it check it out, fill in some water in a pan,insert the thermostate in it and heat up the water..you will see the thermostate ,if functioning start to open around 82 degrees centigrade or so.
Hope this helps!
Oct 27, 2009 | 1999 Honda Cb 400 Super Four
Runs fine for approx 15 mins,then stalls out and wont start again
sounds like coil problem, coils will start cold then get hot and stop. when coil cools will crank up and run till it gets hot, try to replace the ignition coil,dont think it would be a crank sensor, try a coil,thanks robert b.
Jun 19, 2009 | 1993 Jeep Cherokee Country
WONT START WHEN HOT STARTES FINE WHEN COLD WHEN
sounds like you head gasket problem or maybe cooling system needs to be bleed.
Jun 19, 2009 | 1995 Honda VFR 400 R NC30
Mazda 626, 1995 won't start
FUEL PUMP MIGHT NOT WORK. CHECK TO SEE IF IT HAS SPARK.
Oct 28, 2008 | 1995 Mazda 626
Help...
If you were experiencing a failure just after a heating cycle but not on a cold start, I would suspect an electrical component failure. As the component cools, it makes contact and allows the furnace to operate. This will change and not for the better. Depending on what your system has for electrical components, I suspect either a relay or transformer. At any rate, get a technician in front of it so he/she can diagnosis it under both cold start and hot start conditions. It will help if you turn off your system so it will be cool when the tech gets there.
Nov 25, 2007 | Heating & Cooling
Traxxas Rc Revo Nitro Monster Truck Logo
191 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
gbob59
paul tooker
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
