Question about Numatic GVE370 Canister Wet/Dry Vacuum
Warter coming out of the motor on top when using on wet cleaning my carpet.
  • 174 Answers
It is too full and/or the float is working.
Take the top off and set it away from the tank and run the motor for 10 minutes to dry out the vacuum motor. Check that the float isn't stuck and be sure to empty the tank regularly
Posted on Jul 03, 2009
  • firehead Jul 03, 2009
    another thought. If there is carpet cleaner in you carpet it may be foaming and the float in the vac won't work on foam. You need to put defoamer in the tank
I have a Delonghi Multi Vac M31 and have never used the wet part...I would like to clean my carpet using the wet vacuum...can you please tell me how I can do this? Many thanks
A good place to start is the owner's manual. If you don't have one, you can google the make and model of your multi-vac to get another copy.
Most wet-vacs work off the same principle. Pre-vacuum the carpet to make sure there is not normal surface dirt and dust. Next Squirt on hot soapy water, scrub it in - then suck up the dirt and collect the dirty water.
So after vacuuming the area to be wet-vacuumed and you are lucky enough to have a separate reservoir on the wet-vac unit - add pre-mixed carpet cleaner into hot tap water (with carpet cleaner mixed into it by the ratios described on the carpet cleaner soap bottle) to the multi-vac water reservoir (from a quick look, the Delonghi doesn't have one) . With the settings for wet vac (per the owners manual), squeeze the trigger for applying the carpet cleaner. Typically, you will go slower than normal vacuuming. Give it a chance to soak in and dissolve/lift the grim and dirt. Come back slowly to pull the dirty water out of the carpet.
There are multi-wet vacs (like the M31) that don't have a reservoir for the carpet cleaner. In that case, you need to pre-mix a couple of gallons of carpet clean in a separate container or bucket. Next spray or sprinkle carpet cleaner onto/into the carpet. Try to scrub the cleaner into the carpet to really get at the dirt and lift it. Next is to vacuum up the wet stuff.
Some carpet cleaners do not contain an anti-foaming agent. I recommend you either add an anti-foaming agent or buy a carpet clean product that already contains it - otherwise, it tends to be a big mess that takes a lot more time.
I hope these tips help.
Nov 07, 2014 | Vacuums
Tip
Aerus Electrolux: Don't Void Your Warranty
Aerus Electrolux Warranty
Aerus carries a great warranty on their machines, up to 20 years limited on top of the line models. However, there are some things that WILL void the warranty. The following are probably the most common.
Use of generic/made-to-fit bags. There’s a reason genuine bags are strongly advised for use with the Aerus and previous Electrolux vacuums, and it’s not just the strength of the bag. Fine dust particles will get through generic bags and result in a damaged motor.
Vacuuming wet carpet and liquids. Although you may try to make sure you don’t use your vacuum on liquids, children, other family members, and/or house cleaners won’t necessarily be as careful/caring. If kids notice the vacuum doesn’t work anymore, they may try to hide the evidence, thus you may not know about the problem.
Keep in mind that if you have your carpet steam cleaned, it can take a week or more to thoroughly dry. Vacuuming during this time will result in water/mud getting into the motor, ruining it almost immediately. A wet bag will also usually break open, sending contents through the motor. The motor will have to be replaced, but it won’t be covered by a warranty.
Dismantling of vacuum by unauthorized persons. If you’re having a problem with your vacuum, and you think it’s an easy, quick fix, don’t. You may get it fixed, but this will void the warranty for future problems. It’s simply not worth it.
Commercial use. The Aerus commercial upright is made for tougher work, but only carries a one year limited warranty. Even though your machine may have a longer, better warranty when used properly, using it as part of a cleaning or similar business voids the warranty. Solution; Don’t do it.
Aerus Electrolux does NOT warranty machines sold over the internet, such as on E-bay. Only those purchased through an authorized franchise or representative carry Aerus' warranty.
Be aware of your machines’ capabilities and warranties. An Aerus Electrolux owner has made a wise investment in a top-of-the-line home cleaning system and generally desires to maintain the system in prime working condition, with full benefits.
Contact Aerus for additional information. You can find a local shop/consultant through their home page: http://aerushome.com/
on Aug 22, 2010 | Vacuums
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
How do i use my bissell 7920
The 7920 is a great little carpet shampooing vacuum. Look up manual information for detailed assembly and starting/breakdown procedures. Make certain that the carpet/floor has been vacuumed previous to cleaning with the shampooer! The small nozzle opening will get clogged with as little as a toothpick or cheerio! Step on the rear release arm pedal and drop the handle down to the floor, Pull up on the resevoir bucket handle and place the handle of the resevoir back down to open the top of the tank and fill the bladder with hot water. Replace bucket top and place bucket back into vacuum. Raise the handle until it clicks into place. Fill on board soap/shampoo dispenser by lifting out of chamber on unit and fill with appropriate Bissell or upright shanpoo cleaner. Replace unit and make certain the top is tight. Plug unit in and turn on both vaccuum switch and preheat water switch and wait approx. 2 minutes to get water hot enough to proceed with cleaning. Start by rollling cleaner onto carpet and engage trigger approx 2-3' pathway away from you and then release trigger and draw vacuum /shamppoooer back over wetted area, repeat without using water again unless heavier traffic area. Do not over wet area draw unit back and forth a few times until water runs clear thru the front clear window. Proceed to make another path along side cleaned area and so on.
Once you hear the water run out or you have finished cleaning an area then shut of heater and vacuum. release handle with foot pedal release and lift out bucket and pour out dirty water and rinse area/tank /resevoir etc. You should also clean the small red filter in the resevoir of any debris by popping out and replacing. Also, there is an onboard filter under the clear window (where spinner is located) . unscrew clear top , take out spinner device and pull out small plastic screen and rinse or blowout. Clean also the front clear cover if there is debris, by rinsing off with sprayer or wiping clean. You may also find that you have to take off the clear plastic hood window, by unscrewing two screws on either side of nozzle opening (top ) and rinse out as well. Do not, get water under unit into motor area. Place unit upright and in a warm place.. Do not let freeze if in climate that is known to freeze. Good luck cleaning!!
Apr 23, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Carpet not getting moist
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
eyrye
Mar 09, 2010 | Bissell 8910 ProHeat Clear View Upright...
The water will not come out, indicator not spinning
trash it! I am having the same problem. I am so mad at my carpet cleaner, I have only used it 2 times. JUNK!
Mar 30, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Carpet stained
Ok in the future try to have carpet cleaned only by a pro. For spot cleaning use white paper towels or dish towels and warm water. (ONLY WHITE) 99% of fabric is white and then dyed to color and if you use a color cloth you might pull the dye from the cloth into the carpet. Now what you can try is your basic dishwashing detergent like electrosal with warm water and a dishtowel. little at a time try to blot not rub. try AFTA if that doesnt work. wet the rag first with warm water. pour the afta on the wet rag not on the carpet.
Jun 10, 2008 | Bissell OxyKIC - Oxygen Activated Carpet...
Numatic GVE370 Canister Wet/Dry Vacuum Logo
242 people viewed this question
Top Numatic Vacuums Experts
Chris Nomland
Chris Nomland
Andrew Taylor
Andrew Taylor
Are you a Numatic Vacuum Expert? Answer questions, earn points and help others
