ThinkPad T21 dark monitor. What part to change?
Hello, I have an IBM ThinkPad T21 notebook and when I turn it on, the LCD screen gets too dark that you can barely see anything shown on the screen.
Some time ago I used to press many times with heavy pressure the part of the panel over the inverter and it worked, but now it doesn't work anymore. I can let it turned for hours and it keeps dark.
One curious thing is that if i plug it on an external monitor, the image is normal on the monitor and after about half an hour the image shows on LCD screen. The image is shown ''yellowrized'' (I can see some traces of yellow light coming from the bottom sides of the screen), but what before didn't work now works.
So I want to know what part I have to change. Is it the inverter, the backlight or the LCD flat?
Is it hard to change tha last two ones?
If you need additional details you can ask me.
Thank you!!
  • Divya K
    Divya K May 11, 2010
    You can replace only the back light as in its not a seperate part , you will have to replace the whole LCD panel, before that check in BIOS as well, if the same issue on BIOS, Go for LCD replacement
    Master:
  • 404 Answers
Seems like a bad inverter that needs changing
Posted on Jul 03, 2009
How to remove the display on IBM T21 laptop
The laptop screen is secured to the laptop with screws at the hinges.
There are usually two screws per hinge. The LCD screen has one ribbon cable and possibly a power connector for the back lighting attached to the motherboard near the hinges. Disconnect these before you lift the LCD off the base, they are under the plastic panel above the function keys next to the hinges.
Feb 03, 2009 | IBM ThinkPad T21 Notebook
Thinkpad T21 Boot Problems Problems
This is caused by a system board failure. Take the laptop apart again and check all of your connections. Also make sure the ram and processor are seated correctly. You can also try hooking up an external monitor to see if any errors display. This may be an indication that the video cable connected to the system board is not fully connected.
From IBM website:
Two short beeps - System board failure
Dec 20, 2008 | IBM ThinkPad T21 Notebook
Back light on ibm t21
This is an known problem I think you must replace the backlight:
look for example ebay partnr: 260327530145
only for example if this is your problem.
PRODUCTS ITEMS
LCD CCFL BACKLIGHT LAMP IBM THINKPAD T20 T21 14.1" SCREEN
LAPTOP & MONITOR LCD SCREEN PROBLEMS
SOME COMMON SYMPTOMS FOR BACKLIGHT LAMP REPLACEMENT
- Flickering, red or pinkish hue to display and even total darkness. These symptoms are a result of a failed or ageing backlight or a failed, damaged. This is caused by the defective backlight lamp and all you need to do is replace the backlight.
DESCRIPTION
Our high brightness LCD cold cathode lamp (CCFL) with long life, it is more than 50000 hours, with Japanese new cathode, phosphor, glass, and other materials, they are perfect for all LCD backlight application and other purpose, such as instrumentation, medical devices, and all type devices.
COMPATIBLE MODELS
Suit for
Any 14.1” LCD Screen (2.0mm in diameter and 290mm Length) and (2.0mm in diameter and 292mm Length)
CUSTOMER SERVICE / CONTACT US
Email: mkproco@gmail.com (12 Hours Response Time)
Oct 14, 2008 | IBM ThinkPad T21 Notebook
Suspend light
Is your laptops motherboard and vga chipset working? Please try to connect the laptop to another monitor if you are unable to get any image out it might be that the 2nd output is disable OR your motherboard or vga chipset has failed.
If the laptop works on another monitor, then there is still something wrong on the lcd.
But I think there is a more serious problem.
if you need more assitance let me know. good luck.
Mar 30, 2008 | IBM ThinkPad T21 Notebook
LCD and inverter replaced, still dark
The most common fault here is certainly the screen cable - it is available cheaply on ebay - I'm in the UK so here is a local example in this link:
T23 Cable
the other slim possibility is failure of the backlight switch which detects when the screen lid is closed.
Please rate this assistance as we depend on your feedback - hopefully this should be fixya - thanks,
Mar 24, 2008 | IBM ThinkPad T21 Notebook
IBM ThinkPad T21 / Network
To my knowledge an IBM ThinkPad T21 originally was shipped out from the manufacturer without a WiFi networking interface, sorry.
Kind regards.
Feb 08, 2008 | IBM ThinkPad T21 Notebook
Cracked TFT screen on IBM Thinkpad T21
HERE IS A LIST OF P/N THAT WILL WORK
46L4843 LCD 14.1
05K9942 LCD XGA 14.1
05K9678
05K9668
05K9567
05K9944 ALL SUB TO 04L2348
Oct 16, 2007 | IBM ThinkPad T21 2648 Notebook
Computers & Internet Logo
279 people viewed this question
David Payne
David Payne
