Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
DU1100XTPBA Blinking Lights----->Not Operable
I have a Whirpool Quiet Partner II DU 1100XTPBA which a little over a year old. On the display,
the Start/Resume Button Light Blinks as well as the Scour Button Light. The Pots and Pans light remains illumatinated, however, none of the other buttons will activate when pressed/engaged. Faintly you can view a dim glow coming from both the Drying and Sanitized Sensor Lights. The Machine will not turn on, nor will the Cancel/Drain Function. Could you please give me some guidance, it would be much appreciated. Thank You.
yalmer
  • 552 Answers
SOURCE: Kenmore Dishwasher #15769
Try this solution first
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Posted on Feb 16, 2008
  • 4 Answers
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
SOURCE: My Whirlpool Quiet Partner 111
Disconnect your circuit breaker for 20 minutes and then reset. It should reset your dishwasher.
Posted on Jan 28, 2009
  • 52 Answers
SOURCE: quiet partner II is stuck in cancel/drain mode...
you need a new cycle selector ...or "timer "....
Posted on Jul 25, 2009
  • 12 Answers
SOURCE: pots and pans and normal wash blinking
Try resetting it. Locate the switch in your breaker box, and flip it off- then on again. Hope that works!
Posted on Aug 09, 2009
Whirpool quiet partner 3 gold. panel lights work and say it is wasing but doesn't start
The timing circuit may be defective and the circuit board needs replacing. Have an authorized serviceman do a continuity test on the board and have it rest to factory specs.
Feb 27, 2014 | Dishwashers
How do I reset blinking lights?
Switch the breaker off for a minute.....
Aug 26, 2012 | Dishwashers
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
What is the reset code for a whirpool plus quiet partner III
heated dry and high temp wash and toggle back and forth these 2 keys within 8 seconds till all the lights light up.
Aug 30, 2010 | Dishwashers
Will not drain
Here is a tip that I wrote about your problem. It will give you some things to check that should help you fix your problem.
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
Heatman101
Feb 23, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I have a whirlpool Quiet partner II. It will not fill w/water.
ck the float in bottom of tank . it may be stuck n the up pos .. moce it up and down and listen for click of the sw .. very common . also the water valve may have failed and it will need replaceing . mm
Dec 07, 2009 | Washing Machines
Blinking light on start button and no action!
Call a technician from the place you purchased it. It should still be under warranty. If not by them, then I would try the manufacturer. Warranty Job
Dec 04, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner II
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 26, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
136 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
