Question about Vtech 5.8GHz Cordless Phone with Digital Answering System
I have a vtech i6765 with one extra handset, How do I reset it back to factory settings?
  • 749 Answers
That option will be in the phone's settings, just scroll down.
Posted on Jul 03, 2009
My vtech handsets say line in use...the intercom buttton is on and the red light aove charge is lite. how do i turn off the intercom it was pressed in error and i have been without a phone for the pa
Try the factory reset initialization. Put the set back to factory settings. Sounds like the power on and timer are set together. I had one of these and needed to reset to fix the problem. The procedure is in the back of the manual.
Nov 24, 2014 | Televison & Video
I just purchased from Vtech LS6475 plus two accessory handsets LS6405. The two handsets that were packaged with the base registered without a problem. The two access. hs's are not registering. They go...
the accessory hand sets have to be vthech ls5475 units the same as what came in the original packaging
the extras you got will not register with an incorrect base
take them back and exchange for the correct units
Feb 08, 2018 | Vtech LS6204 1.9 GHz 1-Line Cordless...
Vtech 6.0 deregister
Getting startedReplace a handsetIf you want to replace a handset or reassign the designated handset numberof a registered handset, you must deregister all the handsets and thenindividually register each handset.To make deregistration easier, read all of the instructions on this page beforeyou begin. To deregister all handsets:Press and hold FIND HANDSET on the telephone base for about 101.seconds (until the IN USE light on the telephone base turns on and starts toflash), then release FIND HANDSET.Press and release FIND HANDSET again. You must press FIND HANDSET2.while the IN USE light is still flashing. The IN USE light flashes forapproximately seven seconds.All system handsets show CONNECTING... The deregistration process3.takes about 10 seconds to complete. All handsets show NOT REGISTEREDwhen the deregistration completes.If deregistration fails, you might need to reset the telephone and try again.To reset:1.Pick up the registered handset and then press talk/flash.Press OFF/CLEAR and place the handset back in the telephone base.2.-OR-1.Unplug the power from the telephone base, then plug it back in.You cannot deregister a handset if any system handset is in use.
May 29, 2010 | Vtech Cordless 6041 Phone
I get constant "Memory Full" error.
they are made to cheap to repair .buy a new one
Oct 25, 2017 | Vtech i5808 Cordless Expansion Handset
VTech 2420 handset will not promp me to key in the base ID
If the other three handsets work ok then you have a defective handset.
Mar 17, 2017 | Vtech VT 40-2420 Cordless Expansion...
Can put in base id
Did you try this (from the i5801 manual) -
To register a handset to the base, follow these steps:
Step 1: If ENTER BASE ID is displayed on the handset, proceed to the next step; if not, press MENU on the handset, then press ▼ until REGISTER is highlighted; now press OK.
Step 2: Locate the 15-digit Base ID number by pressing, at the base: MENU, then press until DISPLAY BASE-ID is highlighted, then press OK.
Step 3: Carefully enter this number using the handset dialpad. If you make a mistake, press to backspace. When finished, press OK.
In a few moments, the handset will be assigned a number (1-6). This will be the lowest available number in the sequence not previously assigned to another system handset.
Step 4: Repeat the procedure for any other unregistered system handsets.
Reply back if you have success. The Base ID is not from the bottom of the base unit, but is something you get by following Step 2 above.
Feb 04, 2009 | Vtech i5807 (735078006394) Cordless...
2 of my 4 vtech handsets keep giving me a 'check battery warning'
Try to reset the handset from handset menu, maybe the eeprom setting for low battery warning threshold have been ereased . Also check ,if the battery is the oregional battery for the phone.
Jan 21, 2009 | Vtech Lands Phones
VTECH LS6125-2
The 6125-2 only supports 2 handsets.
Oct 29, 2008 | Vtech LS6125-2 1.9 GHz Twin 1-Line...
Switching from pulse to tone dialing (there is no switch on the base unit)
hold the select button down a few seconds until you'll see a 'tn' on the readout. this sets it to tone. hold it down again and it will set back to 'Pu' for pulse. i figured this out by accident. the losers at vtech never answered my question.
Oct 25, 2008 | Vtech 2467 Cordless Phone
Only base and one extra handset
I would not have thought so.
It should work with just one hand set
Jul 01, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
306 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
