Question about Dell E173FP 17" LCD Flat Panel Monitor
Dell monitor shows blank screen, green power light stays on
Dell Monitor E173FP blank screen, green power light stays on constantly and won't turn off. Unplug and plug in, self diagnostics don't come on.
  • Dell Master
  • 1,684 Answers
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 03, 2009
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Sep 30, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
My monitor will not come on, I have a green power light
you have a bad monitor or video card call 4 free help 3363926682
Apr 15, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Dell Monitor Problems
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Jul 17, 2009 | Dell E173FP 17" LCD Monitor
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Final Answer to Dell E173FP blank screen problem?
Check out this link http://www.lcdrepair.us/Installation.html
They have help videos on that model and sell repair kits as well as the whole board.
Jun 12, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Flickering switch light, blank screen
Hi, First of all it is not advisable to open up monitors without proper tools as they contain hazardous elements. Dell monitors however do have a 3 year SEPARATE warranty. Check on the back of the monitor and look for the monitor serial number. is should start with CN-xxxxx-,, or JP-XXXXX-. give that to a dell tech and they should be able to replace that.
Oct 01, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP 17" LCD Flat Panel Monitor Logo
580 people viewed this question
Alun Cox
