Question about Pioneer DEH-1100 CD Player
New head unit worked for a bit, stopped working
And now the old one won't work either
... except it's not the fuses.
We've checked the fuses with an ammeter. We've checked the fuse in the head unit and the one in the fuse board of the car. I assume there's no other one?
The new head unit won't work and neither will the old one, now (although it does occasionally light up for a brief moment and stop working. I have a Pioneer DEH-1100MP and am replacing a factory standard Rover 45 cassette player (which I think was re-installed recently - just bought the car).
Also checked the wires running to and from the unit, which are running at a current both ways of 12.6 or thereabouts. I'm tempted to think there's something wrong with the new head unit but can't figure out why the old one won't work (also just tried replacing fuse on fuse board)
The sellers of the CD player are willing to take it back, but if there's nothing wrong I will have to pay delivery charges to get back something that doesn't work. I'd like to avoid that if possible!
And we did swap the yellow and red wires as we should have done, and then tried the other way after it wouldn't turn on again.
MNfisherman
  • 11896 Answers
SOURCE: can I install a pionerr DEH 1100mp cd player to my
Oh yes. Definately. You hook up red and yellow wires together on the positive side of battery. Black negative wire goes to negative on battery. That's all there is to it. Besides the speaker wire which you will have a diagram on the bottom of the cd player to tell you which wire is which
Posted on Jul 10, 2009
  • 4 Answers
SOURCE: Pioneer DEH-1100MP stereo no working
Is it older then a year? warranty or call18004211404. If your fuse is good check these. check you harness for a GOOD ground, check for power with a meter reader. For some reason on these units if your constant 12v and ignition 12v are both not hooked up it wont even do a thing. make sure both are connected. no loose connects?
Posted on Aug 16, 2009
SOURCE: changing clock on pioneer deh-1100mp
turn the unit off.then push the power button and hold till clock flashes,then use your arrow keys
Posted on Dec 12, 2009
  • 11 Answers
SOURCE: the display on my DEH-1100MP is fine at night, but
check that the illum (usually orange)wire is not incorrectly hooked up to acc or perm power as it dims the display for night driving (supposed to be hooked up to your headlight parker switch.)
Posted on Jun 18, 2010
jimdoe
  • 4 Answers
SOURCE: No audio on Pioneer DEH-1100MP
I'm having the same problem worked for a couple of days then just stopped playing music
Posted on Nov 30, 2010
Eject button won't work
What is the unit? There are often times in these new systems a belt or gear mechanism that moves the head base as well as other parts around. As units get older they need lubrication and the grease hardens to where they do not move as well. Belts also stretch and need to be replaced. When the head base mechanism is up or the mechanical alignment of the mechanism is NOT in stop mode or eject position the door is blocked from allowing it to open. The solution is to open the unit up and release the tape by a orderly means and then to work on it or have it worked on by someone who understands these units.
Dec 16, 2012 | Audio Players & Recorders
Can I replace the head unit in a 2004 saab 9-3 ? I've heard you can't because to car won't accept any other radios in it . I'm looking to replace it with a touch screen head unit .
Thanks for the help ...so your saying that if I for example buy a ...pioneer stereo that is the right size then it should have no problem hooking into the car with out any fancy wire work ....I'm for iliac with normal installation ( done it before ) but I'm just a little intimidated by some of the sites saying that you can't install a after market radio into a saab because it won't exempt it and all that stuff . But any right size stereo should work your telling me ?
Nov 06, 2012 | 2004 Saab 9-3
What's your problem?The horn won't work, the light that is supposed to go on when you open the doors won't work, the cigarette lighter won't work, and the head unit won't work
on 1987 all you mentioned are on same fuse #11 located in fuse box below steering wheel 3rd row 3rd fuse from left next to either a blank space if you do not have power windows,or next to silver circuit breaker if you do have power windows.
May 23, 2012 | 1987 Chevrolet Camaro
2004 Jeep Grand Cherokee Laredo: electrical system starting to fail?? Hi! I hope someone can point me in the right direction :) I have a 2004 JGC-L that I LOVE, but the electrical system seems to be...
note that you never once said car can be driven? why?
job1, can you do job 1?
battery is going dead
if head lamps are dim its battery going dead, (not dash HEADs?)
notice is did not say battery was bad only discharged.
if engine starts is charge.battery lamp glowing.
i engine is dead, can crank it.
get a jump, call AAATOW
or find a loaned battery that is charged.
buy a battery charger and use it.
also cars can have phantom drains, as you sleep battery goes dead. (ask)
Mar 15, 2017 | 2004 Jeep Grand Cherokee
The unit just stopped heating and drying the clothes.The burner on my LP Kenmore dryer won't light, otherwise everything else works just fine. I've have taken everything apart and cleaned out all...
Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty
Jul 28, 2011 | Kenmore Dryers
Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
Hello, I have a Ford escort 1.8 55D van. A few months back I fitted a new indicator stalk unit for the MOT as the high beam use to flicker on its own, all then fine. A couple of weeks ago the indicators...
typical UK reg motor they corrode like ?-?-? ,i suspect that your horn has stuck up with corrosion and the indicators is the hazard light warning switch faulty .But i could be wrong and often am but check it out anyway.I try not to repair UK or northern europeon vehicles anymore as i spend more time cutting off rusty bolts and seized bits than whats the cars worth compared to spanish vehicles that can be 20 yrs old and i just whistle and the bits come undone
Jul 18, 2011 | Ford Escort Cars & Trucks
I replaced a cracked rear tail light with an after market new light. Now the brake light won't work but reverse lights and directional signal do. The bulbs are fine as I've moved them around and...
  • If there are no brake lights period the check the stop switch (brake light switch)
  • This is attached to the upper part of the brake pedal itself. Should be a little wire off of it. When that goes bad the brake lights will not work at all.
  • Please note that the fuse for "brakes" is ABS only and has no bearing on the brake lights themselves working.
Regards, Tony
May 30, 2011 | 2003 Jeep Grand Cherokee
Radio Works, but Screen is out, Fuse Ok
If everything else is still working and the Fuse is good it is Because the Internal Lighting on the Head Unit is Burnt out. The only way to Fix this is to get a New Head Unit.
Jan 10, 2009 | 2004 Honda Accord
Pioneer DEH-1100 CD Player Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
