Question about Dryers
My clothes dryer will not produce hot air to dry clothes, only cold or warm...can you help?
  • 82 Answers
Heater element or thero stats have gone u need a expert to check these with a meter
Posted on Jul 03, 2009
Frigidaire FEX831CS0 does not seem to be producing warm water with the warm/cold cycle. It does produce hot water. The dryer takes way too long to dry.
Thank you for your inquiry, friend!
I understand that you are having temperature issues within your Frigidaire laundry center. I see that you feel changing the thermal limiter may fix your issue. That could help or it could be a possible issue with your element, water valve, or in home water supply. You may want to check and make sure the dryer vent is not clogged or restricted that could cause long dry times. With the water supply you may be able to run the sink closest to your washer in order to help boost the amount of hot water that becomes accessible inside of your washer. I hope all this information is useful for you. -Matt
Feb 14, 2015 | Frigidaire Washing Machines
After replacing the thermal fuse one my electric kenmore dryer, there is heat but clothes are not drying and is blowing out cold air
Might be the timer. Might just need cleaning. Take a look at my home video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 27, 2012 | Kenmore Dryers
NOT DRYER CLOTHS LIKE IT USE TO TAKING MUCH LONGER
Check for clogs in the vent air line. If dryer lint or some obstruction is slowing the air flow it will take longer to dry clothes. Also the dryer may not be getting hot enough. Check to see if the clothes feel hot or warm when you reach inside. If it feels hot enough it is likely an issue with air flow. heat and air flow are required to dry clothes.
Oct 02, 2010 | Frigidaire Electric Dryer
My clothes come out wet after running for a length of time but they are hot
You have an vent issue..If the clothes are hot but not drying your not getting proper air circulation, you need airflow thru the unit to help remove the moisture from the clothing other wise you end up with warm moist clothing... Start unit and go outside to where the dryer vent comes thru the wall and check the airflow with your hand ,you should feel a good flow of warm air. If not some where between the unit and the vent their is a restriction either in the flex duct or the duct work in the wall which will need cleaned out before the clothes will dry in a normal time frame..Plus it cost a lot to run the dryer 2 or 3 cycles to dry clothes Hope this helps Good Luck
Aug 26, 2010 | Maytag Dryers
HDV6UK...clothes are warm but not drying!! help
Vent going away from the dryer is stopped up full of lint or the vent tubing is collapsed causing the hot wet air to remain in your dryer.
Nov 19, 2009 | Hoover Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Dryer isn't getting as hot as it should, clothes take twice as long to dry
clean out your wall vent,dryer hose and lint trap that should do it,what happens if you have a clogged vent the dryer keeps the wet hot air in loner and it take twice as long to dry-mike
Apr 20, 2009 | Dryers
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
Dryers Logo
42 people viewed this question
Top Dryers Experts
